POR 15 question
Discussion in 'Questions & Suggestions' started by famous59, Feb 6, 2004.
  1. famous59
    famous59
    from dallas, tx
    Has anyone ever used the epoxy putty or the por patch from POR 15 ? I have a hole in the corner of my roof close to the piller and was wonder if the putty my be my best bet. The hole is alittle smaller then the roundness of a pinky finger. Of course I can fiberglass or metal fill, just trying to fix correctly to where I do not have it pop back up with a bubble under fresh paint. any comments ?
  2. rdstr31
    rdstr31
    from Ney, OH
    I've used the POR 15 putty to plug small holes, but I can't remember doing one the size of a pinkie finger. I know the suff doesn't shrink and dries rock hard, so you probably shouldn't have a problem with it using it on a hole that size. I also used it to repair cracks in a 40 Ford steering wheel and it worked great!
  3. kyle paul
    kyle paul
    from sac
    dude if the size of the hole is the same as your pinke and you plan on keepin the car for a while you should probally weld it.
  4. famous59
    famous59
    from dallas, tx
    Thanks for your response. I am planning on weding the whole, but now I knnow that the putty gets good recomendations on smaller holes. Thanks again
