POR 15 rumors...help me out here?
Discussion in 'The Hokey Ass Message Board' started by ford9inch, Dec 31, 2008.
  1. ford9inch
    ford9inch
    A buddy of mine told me that POR 15 won't stick to bare metal...paint...bondo...pretty much anything...besides rust...is this true?
  2. fiveofeen
    fiveofeen
    it goes well on bare metal once you prep it as they direct you to.
    www.por15store.com read up
  3. cadillac nut
    cadillac nut
    follow their instructions and you'll be fine ..been using their stuff for ....15 years (?) now ..
  4. gnarleynick
    gnarleynick
    from ____
    I had no problem doing my bare metal fenderwells. Looked pretty tough too.
  5. zzford
    zzford
    That stuff sticks to ANYTHING! Don't believe me? wash your hands in it!
  6. glenn33
    glenn33
    from Browns, IL
    POR-15 needs a surface with "tooth" to adhere properly. If you are working with new metal either sand blast or use their metal prep to give it an etch. Rust is a natural etch that's why it sticks so well to rusty metal.
  7. I used the POR 15 silver color, looked great till it sat in the hot Texas sun for a day, then it turned a rather nice greenish tint, there is no UV protection so it will fade or change colors on you:eek:
  8. HotRod33
    HotRod33
    on new metal us a degreaser and then a metal prep and it will be fine.....If it is going to be exposed to uv rays[sunlight] it needs a top coat.....pors makes one that they call chassie black ....either in gloss or satin finish...
  9. enjenjo
    enjenjo
    from swanton oh
    Yes it's true. If you take the time to read the instructions it says so there. It will not even stick to cured POR 15!
    Now, if you etch the bare metal, sand the paint, ect it will stick fine. It need some tooth to stick.
  10. bigolds
    bigolds
    They have UV safe formulas too!!! Got the semi-gloss black on the deck of my car trailer....looks great!!!
  11. willysguy
    willysguy
    from Canada
    Now that's funny! :) I've ran out of rubber gloves while using it and you're right.
  12. Voodoowagon
    Voodoowagon
    from Fort worth
    Bare metal with POR 15 marine clean
    Bare metal with POR 15 metal ready to etch the metal and prepare it for paint
    One coat of POR 15, still had to go back for one more coat
    I dont even think you have to go down to bare metal if you dont desire, we just wanted to get rid of the undercoating on the frame. On other applications we have just knocked the loose rust off and painted and it looks just as good.
  13. Mr Haney
    Mr Haney
    wore it on my face for two weeks after painting undercarriage of my 30A with it. Do not cut it with thinner even though they tell you you can. Works the best full strength. ABSOLUTE must to blast or rough up [ degrease also ] clean metal surface or shit will peel offf in sheets. As other's have instructed you......why not just use 26.00 per gallon Blitz Black paint from tractor supply ? ? good stuff and cheaper.
    POR 15 sucks when you try and sand it or remove it later..my 2 cents whataiknowfuckit
