POR paint?
Discussion in 'The Hokey Ass Message Board' started by baspinall, Jul 26, 2010.
  1. baspinall
    baspinall
    from SE PA
    How do you think POR would hold up for backing plates, axle, perches etc.?
    I have used it on floors and a couple other areas but never somewhere that is more open to getting chipped.
  2. grits
    grits
    Are you talking about the primer or are they making paint also?
  3. hellonwheels
    hellonwheels
    from Bastrop
    Good luck chipping that stuff, you'll need a jackhammer.
  4. baspinall
    baspinall
    from SE PA
    The black POR 15. It a rust preventative paint but its pretty tough.
  5. chopolds
    chopolds
    from howell, nj
    I use their Ch***is Black on frames, rears, suspension parts a lot, holds up very well, Use it over the regular POR-15 silver as a "primer". Just follow the instructions to the letter!
  6. baspinall
    baspinall
    from SE PA
    That's how I felt when I used it on my Nomad floors. It flowed real nice as well.
  7. baspinall
    baspinall
    from SE PA
    Bad part is if you don't like it when your done you will never get it off and I think it's hard to paint over top of it even with scuffing.
  8. grits
    grits
    The POR has no U/V protectant and will change colors when exposed to the sun light, it will happen in one day, I used it on the coupe, the silver one that is, set in the driveway for about six hours and it turned green.
  9. baspinall
    baspinall
    from SE PA
    Ouch, don't want that to happen! I have a couple cans of the black that's why I ask.
    Never tried the ch***is stuff. Sounds like it may be a better route for the axle and stuff. I almost like the real color of the axle and perch's.
  10. baspinall
    baspinall
    from SE PA
    Ok< i just read another thread saying that if this paint is used on new parts ie. my axle & spring perch's it will not stick and will peel.
  11. grits
    grits
    thats not good
  12. baspinall
    baspinall
    from SE PA
    Think I'll go with a ch***is paint.
  13. It needs rust to activate it to it's best.
  14. it still might work on the new parts you just may have to sand them with at least 80 grit sand paper on a da to get some good adhesion. paint does not like to stick to smooth surfaces no matter what it is
  15. Bearing Burner
    Bearing Burner
    from W. MA
    You might want to try etching them in one of the rust removers. I had poor adhesion
    on new tubing until I etched it.
  16. oldskool30
    oldskool30
    I think their directions say to sand blast new metal , followed by washing with soap and water . They also make UV resistant topcoats for the por 15 . They have been very helpful to me over the phone as far as prep , etc. I plan on using it on the frame of my current build
  17. mike1951
    mike1951
    from Colorado
    ch***is stuff is GREAT, just don't get it on anything not car related...like hands or clothes..it NEVER comes off...
  18. baspinall
    baspinall
    from SE PA
    I'm looking into the POR Ch***is paint. It's supposed to have good UV resistance. I have used the other POR 15 with the right prep and it held up great but was in the light/sun.
  19. KooDaddy
    KooDaddy
    from Wis.
    Don't paint it on or near something thats threaded you'll never get it apart trust me!
    Its very viscus and goes into things that are fastened together and don't come apart after it sets up.
  20. Strodder
    Strodder
    I used POR-15 on 2 different frames. I don't like it at all. It is good rust protection, and very durable though. What I don't like about it is the color isn't consistent. They even said it them self that the Semi Flat wasn't guaranteed to be consistent. Even though I mixed it really good. Both frames came out blotchy, and streaky. They said to just scuff it right after it dries, and paint it. I used Krylon Semi Flat Black. Looks great now, and has a great base coat. I think next time I will try Eastwoods Ceramic Ch***is paint.
    http://www.eastwood.com/undercar-drivetrain/undercar-coatings/eastwood-2k-ceramic-ch***is-black.html
