Technical Port-a-wall
Discussion in 'Traditional Customs' started by jerdan, Oct 16, 2016.
  1. jerdan
    jerdan
    Has anyone had any experience using the port-a-wall whitewalls? How do they look?
  2. 302GMC
    302GMC
    from Idaho
    4 years ... you should know "search" by now.
    LOU WELLS and art dekko like this.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Quick answer, they don't work well with radial tires.
    KK
    LOU WELLS likes this.
  4. wbrw32
    wbrw32
    They don't work well with ANY kind of tire.....
  5. Jalopy Joker
    Jalopy Joker
    look good hanging on wall in your shop
    kiwijeff and Ford52PU like this.
  6. williebill
    williebill
    When I was a little kid, I could spot them from down the street, at night, in a raging monsoon.
    Thought they looked like **** then...... I would hang them on the wall, though.
    LOU WELLS, afaulk and kiwijeff like this.
  7. jcmarz
    jcmarz
    from Chino, Ca
    They're traditional:p:D
    kiwijeff likes this.
  8. Ralphies54
    Ralphies54
    Like S#^*t
  9. Are you serious? Almost 200 threads on the subject and you still have to ask????
  10. Had them on my Dad's '56 Chevy 210, back in 1956.
    No radials back then, but they did manage to space themselves away from the tire sidewall, as time went by.
  11. Raiman1959
    Raiman1959
    I had a 15'' inch set given to me in the 80's as a gift...tried them out of curiosity, but they looked ''cheap'' and didn't fit very well,....I pitched em' in the trash bin!....never thought about hanging them on the wall as decoration at the time...guess they'd be good for that I suppose!
  12. waldo53
    waldo53
    from ID
    Well, I like 'em and they are traditional - I know because none of the kids I knew back in the '50's could go out and buy a new set of whitewalls, we all ran port-a-walls. The secret to success is to find someone who knows how to install them. I called around and found a guy that had been putting them on for years. He carefully placed the port-a-walls around the rim and then inflated the tire in stages, checking to see that the bead on the port-a-walls exactly matched the bead on the rim. Sometimes, he had to deflate the tire and start over, but eventually we got them all done.
    The truck in my avatar is wearing them proudly. I've taken the truck to many a car show and cruise night, and NO one has ever noticed that they aren't real white walls, unless I tell them, or show them, and they are usually amazed. Yes, over time (7 years in my case) they might start to separate a little from the tire. My tires are radials - and I found that by using the smaller (2" or 2 1/2" port-a-walls) that the radial bulge doesn't affect them nearly as much as if you run the larger whitewalls.
    So, if you want to be traditional, and save a grand or so - I say go for it!!
  13. HUSSEY
    HUSSEY
    Oh snap...waldo53 just schooled all the haters!
  14. caton462
    caton462
    Had to use a rubber mallet every time I drove over 90 to get them seated back into the rim, but, they fit well otherwise.
  15. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    You can put a dress on a pig, but,.........:confused:
    LOU WELLS and afaulk like this.
  16. Hemi Joel
    Hemi Joel
    from Minnesota
    I bought a set of 4 potawalls used in November of 1977 and installed them on some old used tires for my 48 Plymouth convertible. I worked at a service station at the time, so I had use of a tire machine to break the bead and install the portalwalls myself. Like Waldo says, as long as you're careful while you inflate so that the portawall is properly positioned, they work out pretty good. That got me by for about two years until I could afford some real white wall tires. Now 40 years later I still have the car, and I still have at least one or two of the Portawalls mounted on spares. They don't lay as nice against the tire as they used to, but what do you expect after 40 years.
  17. D.N.D.
    D.N.D.
    In 57' after school jobs did not pay too much took all my coin to buy this 51' Bel Air, so the white flapper's we IMG.jpg re the thing for us guys
  18. tfeverfred
    tfeverfred
    Hahhaha........ no, man. NO.
  19. 302GMC
    302GMC
    from Idaho
    To Hell with Portawalls ...DND, tell us how you dropped that hardtop ....
  20. D.N.D.
    D.N.D.
    Well ' 302 ' in 57' I was going to ' San Fernando High School ' and if your car was not lowered they would not let you in school LOL , but slammed cars were the deal for sure
    A 6" spindle kit and 2 coils cut in the front, 4" blocks and the springs heat-rearched in the rear and had to cut the rubber snubbers to get any ride at all
    Only had 3/4" of ground clearance and just to much trouble going anywhere so I raised it back up a bit , but it did look good cruising the school each day before cl***'s and Bob's Big Boy too
    Went to go one day let out the clutch and it stalled cause the frame was on the ground with a flat tire , and I did not see it so it was time to get her up a bit
    DND
    rudestude, stevechaos13, lewk and 3 others like this.
  21. waldo53
    waldo53
    from ID
    DND - love that Bel Air !! I drove this '49 Fleetline in 1957, went to HS in Highland Park. We might have seen each other at Bob's, or maybe Van de Kamp's on San Fernando Rd. Yeah, I drove them slammed too, I was forced to "lay frame" everytime I entered a parking lot or a gas station.
    I ran "Fiestas" until just before this pic was taken, someone else decided they liked them too.
    Oh, and yes, those are genuine Port-a-walls, just like almost everyone else ran back in the day.
    stevechaos13, LOU WELLS, lewk and 4 others like this.
  22. Great Chevy pics from the '50's !
  23. 19Fordy
    19Fordy
    Here's some from years ago on bias ply tires. At the time white walls were too expensive.
    Now days, there's no need for them. Plus, they don't hold up well to curb rash and the wind gets under them and makes them "flap" at highway speed.
    302GMC likes this.
  24. Sancho
    Sancho
    @19Fordy Did those have a black ring around the rim to look like narrow whitewalls?
  25. jcmarz
    jcmarz
    from Chino, Ca
    Real Whitewalls are still "TOO EXPENSIVE"!
  26. willys36
    willys36
    had no choice but to use them on m Mysterion clone. If you do use them, do it on bias ply and need replacing every couple yea rs. They rot.
    williebill likes this.
  27. Atwater Mike
    Atwater Mike
    I had a set of 16" on my bud's Model A Coupe. They were thick, and had a 'ridge' around the outside edge.
    They went to L.A. and back 6+ times, never got 'out of whack'...always looked good.
    Someone gave them to me, (I had a channeled Cabriolet, but got some Merc 15" wheels, my neighbor gave me the 8.20 X 15s off his Caddy when he bought U.S.Royal Masters; Front tires came out of some unlucky VW owners' unlocked trunks! My pal 'Thievin Ronny' traded 'em to me for a Harley front wheel and tire!)
    So, Ramsay got 'Porta-Walled'. They always looked good, but some other guys had thin ones that flapped at 40.
    And, NOTHING looked as rank as a torn Porta Wall!
    302GMC likes this.
  28. slowmotion
    slowmotion
    Neighbor kid (older) had 'em on a '53 Chevy. I remember he was always pissin with 'em. Think he canned 'em after not too long.
    Somebody school me on what the hell this means. Some kinda P-C ******** curse word?:rolleyes:
  29. Atwater Mike
    Atwater Mike
    Actually, I heard crankers use it...
  30. lewk
    lewk
    from Mt
    You gotta be hip to the jive daddio.
    "OH SNAP
    (exclamatory phrase) a playful indication of surprise, misfortune, or insult
    popularized by Tracy Morgan of Saturday Night Live, OH SNAP is seemingly derivative of oh no you didn't where an insulted person, for example a guest of Jerry Springer or often a *****y African American woman contends the insult being made against him/her. While derivative of "oh no you di-int," OH SNAP has more of an emphasis on playfulness and can be said by people other than those being insulted.
    Ted: Man, where you been all afternoon?
    Darrin: I had to stop off at your mom's place for a nooner that last a bit longer than expected.
    Ben: OH SNAP! "
    http://www.urbandictionary.com/define.php?term=OH SNAP&utm_source=search-action
