Technical Porta Power Bodywork Tool
Discussion in 'The Hokey Ass Message Board' started by blowby, Mar 13, 2015.
  1. blowby
    blowby
    from Nicasio Ca
    Scored this at an estate sale, $10. But I'm not getting any pressure out of it. There is a fill plug at the back (it's full), two plug things at the head and the knob. Springs and apparently valves under the plug things.
    Do these have to be bled, and how? What is the purpose of the plug with the phillips head? And the one with the hex head? What about the knob, for line pressure I take it.
    TIA
  2. blowby
    blowby
    from Nicasio Ca
    Found a manual with bleeding instruction online, can't delete thread. Sorry. Unless you want to talk about these things...
  3. greaseyknight
    greaseyknight
    from Burley WA
    Thats a unit from Harbor Freight, my dad has one. Seemed to work ok, but that kit looks well loved. The knob on the pump is for it to create pressure, similar to what is on a bottle jack or floor jack.
  4. blowby
    blowby
    from Nicasio Ca
    Thanks greasey. This one says Summit but yeah, likely came out of the same sum-ting factory. I got it bled and working. Now to push some stuff around.
  5. pat59
    pat59
    Hey Blowby,
    What are the dimensions of that steel box?
  6. blowby
    blowby
    from Nicasio Ca
    30x11x7
    Can't have it. :)
  7. pat59
    pat59
    Na, I'm looking for one. The new sets come with a plastic blow molded case. I can't stand it and wanna get a steel box for it. So now I know what size will fit. Thanks. :)
  8. HOTRODPRIMER
    HOTRODPRIMER
    Seals are shot. HRP
  9. Good you got it working,phillips head is the relief valve,other side hex head has 2 balls and
    springs under it(work as check valves).
  10. blowby
    blowby
    from Nicasio Ca
    Thanks BP. HRP, look up! :)
