Technical Porter Vs smity's mufflers
Discussion in 'Traditional Customs' started by chasey32, Dec 6, 2016.
  1. falcongeorge
    falcongeorge
    from BC
    I don't have anything against h-pipes per-se, I have one on my daily driver with full 3" exhaust, and it helps quiet it down a bit. My point is, it's counter-productive to getting a "period" sound.
    Just Gary and TCATTC like this.
  2. dirty old man
    dirty old man
    Exactly my point also George. I get that on my roadster even tough it's an SBC engine, because I have an air gap manifold with no exhaust heat crossover p***age.
  3. bchctybob
    bchctybob
  4. dan31
    dan31
    I put Smithys on my 54 but i think i used the long ones,they are not as loud or "rappy" sounding as i had hoped for.
  5. HUSSEY
    HUSSEY
    30 in. Smithy's on my 52 Chevy, split exhaust, stock 216. I thought it had a nice tone but you couldn't hear it in the car. I would have liked a little bit of tone in the car.
  6. GlennDH
    GlennDH
    from Texas
    I put a set of Brockman Mellow Tone gl***packs on my stock 54 Olds and within 2 weeks replaced them with 30" Smithy's. The Brockmans are very well built but are LOUD. The Smithy's have the exact mellow sound I was looking for. If I were 16 instead of 70 I would have preferred the Brockmans.
    Packrat likes this.
  7. Mt Mike
    Mt Mike
    For my 440 six pac powered 1930 Model A coupe, I built my own from 3" s.s tubing and 4" s.s. outer shell, 30" long. They are packed with s.s. wool. The entire exhaust is all s.s. 3" tubing after the Sanderson block hugger headers. I really didn't find it that difficult to make the mufflers, but I'm a welder by trade which helps. The slash cut ends of the system extend a good 10" past the bumpers and I get plenty of rumble inside of the car. I'm not having any luck downloading my photos so I have to do some homework as I'm tech challenged!
  8. TCATTC
    TCATTC
    Those louvers won't create enough back pressure for you to notice, perforated tube cores are usually louder.
  9. michaelvz51
    michaelvz51
    from So Cal
    I am running Brockman Mellow Tones with Echo cans on my SBC with corvette style exhaust manifolds and 2" tube all the way back.
    harpo1313, -Brent-, Blues4U and 3 others like this.
  10. speedshifter
    speedshifter
  11. speedshifter
    speedshifter
    I had a pair of Porters on my 324 Olds powered roadster. As you know Porters use a stretched garage door spring for a straight through core. The id of the core is 1 5/16", yet inlet & outlet is 2". Excessive back pressure might be the result. I replaced these with $22 gl*** packs from Speedway. They sound great. I feel using insulated hangers will reduce droning. An h pipe will reduce that lovely rumble. In 1958 my friend Craig had a 48 Ford rag top with twin pipes. We jerked off the intake & put pennies in the heat riser p***ages.Then we removed the mufflers, replaced them with flex pipe from the Coast to Coast store. Man it sounded cool! We were in the driveway revving it up, enjoying the results of our hi tech mods. Craigs high strung mother came running out of the house yelling " Craig, Don't you dare drive that thing that way". Craig replied " stand back mother we're blasting off". Craig backed out of the driveway, shoved it in low, tires squealing . Away we went, heading to the local drive inn to show off. Well we were a little deflated when the local fuzz followed us there and gave Craig a $10 ticket for no mufflers. It was great to be a teen ager in the 50's Greg
    Butler 32 and dirty old man like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    found this old video of my corvette after getting its 14" porters
  13. Blues4U
    Blues4U
    from So Cal
    What a *****in car!
  14. michaelvz51
    michaelvz51
    from So Cal
    Thank you Blues4U!
    Blues4U likes this.
  15. abe lugo
    abe lugo
    Chavezk21 likes this.
  16. Jawsmon
    Jawsmon
    Engine master just tested the H pipe against the Y pipe on the dyno. The Y pipe produced a significant increase in hp. The 90 deg. intersection of the H pipe produced turbulence and backpressure. Use an X pipe for dual exhaust so the itersection is 45 deg. angle. This produces the best scavaging and the least amount of backpressure.
  17. Von Brush
    Von Brush
    from Corfu, NY
    I have 27" Smithy's on my 57 Chevy and l like the mellow sound. They are not raspy and are really deep sounding at cruise. If you get on it there is more of a rumble but not annoying. Back in the 60s l had Walker Contenentals on my 56 Ford . They were louder and rapped when you got on them. Now l prefer the mellow sound of the Smithy's. I have an H pipe on my 69 el Camino with turbo mufflers and find the pipe quiets the mufflers somewhat. I do not have the stock crossover pipe on the 57. I guess it is all a matter of taste and age as to what sound you are looking for.
    Sent from my 9024W using The H.A.M.B. mobile app
  18. COCONUTS
    COCONUTS
    Whatever you decide on, just make sure that you can still p*** state inspection.
  19. TCATTC
    TCATTC
    And also the most Euro, un-traditional sound
    fourspd2quad likes this.
  20. LOWDUG37
    LOWDUG37
    I have used Smithy's on flatheads,Y-block and SBC and liked the sound in all 3,I did however put Porter's on a recent build SBC and was disappointed, sounds like aV-6.
  21. 6sally6
    6sally6
    What's worng with straight pipes all the way to the rear bumper? Low back pressure and the sound won't be bouncing up off the pavement. That lil mini SBF won't make a lot of racket anyway so it shouldn't be noisy at all!
    6sally6
  22. iafraser39
    iafraser39
    from Warmland
    I'm running thrush gl*** packs behind my long tube headers.
    Its noisy and drones a lot. Looking for quieter ones.
  23. TCATTC
    TCATTC
    Sounding good and noise are two different things...
    dirty old man likes this.
  24. michaelvz51
    michaelvz51
    from So Cal
    Try moving your gl*** packs as far to the rear of the car as possible
  25. -Brent-
    -Brent-
    This seals it, my 327 is getting Porter's behind it!
    WC145 and Moriarity like this.
  26. Elcohaulic
    Elcohaulic
    I tried them all. The ones I liked best they don't make anymore.. The one's that came in a heavy gauge steel can are not made anymore except for the Porter.. The Porters I bought were very well made but the needed the spring opened up more. I may be wrong but when the spring isn't open the sound couldn't get to the steel packing.. Also the ones with gl*** packing seem to sound better.
    The photo is an old Dougl*** Super Sport muffler. I had two sets of these and they sounded great.
  27. DesmoDog
    DesmoDog
    Mufflers are basically frequency filters. The gl*** cuts down high frequencies but is basically transparent to low frequencies, so you hear a low rumble (***uming the engine produces it to begin with). The steel wool doesn't do much of anything compared to what the gl*** does, so the exhaust will have more high frequency content and sound harsher. The best set up is to use a thin layer of stainless steel wool over the perf tube or spring or whatever, and pack the rest with gl***. Then the stainless is only there to keep the gl*** from getting blown out.
    Blues4U likes this.
  28. 52lomofo
    52lomofo
    You still got the merc?
    Sent from my SM-A520W using The H.A.M.B. mobile app
  29. 52lomofo
    52lomofo
    Or you just posting video
    Speed Gems likes this.
  30. Blues4U
    Blues4U
    from So Cal
    I like reading your comments on exhaust/muffler topics, backed up with experience. Thanks.
    Elcohaulic likes this.
