Posi in a T Bucket?
Discussion in 'The Hokey Ass Message Board' started by louder50, May 30, 2013.
  1. Hdonlybob
    Hdonlybob
    NICE "T"
    And I love that wheel combo !!
    Cheers.....
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Only thing wrong w/ posi in a t-bucket is the LOOSE NUT BEHIND THE WHEEL. !
    dave
  3. storm king
    storm king
    I can't imagine wanting any car that didn't have a posi, or Limited Slip Differential, for the more sophisticated and refined Mopar drivers out there...
  4. :) lsd
  5. tfeverfred
    tfeverfred
    After reading more info on other sites, I will probably get one for my next build. Some info here is good, after weeding through the humor.:D Would there be a minimum or maximum gear ratio for a daily driver? I currently have 3:73. Maybe a 3:52? I'm not really concerned with MPG, just off the line acceleration.
  6. I had a 3.08 posi with a 350hp 350 in The Roach Rod... with a four speed.
    You could dump the clutch at 5000rpm and roast the tires.
    To me... that's what hot roddin gis all about.
    Watch the video from 1:20min and see for yourself...
    <iframe width="420" height="315" src="http://www.youtube.com/embed/hcRfvUGL67k" frameborder="0" allowfullscreen></iframe>
    Sam
  7. I think those of us up here in the north country probably have a "leg up" due to snow and ice. It gets to be a long winter if you don't know how to drive in slippery conditions and high power to weight ratio is just slippery conditions!
  8. DERPR30
    DERPR30
    from HARVEY LA
    I just installed a 8.8 explorer rear end w/3.73 limited slip and have not had any problems but i dont drive in the rain
  9. louder50
    louder50
    from Michigan
    Do the "posi" rear ends that you find in an S-10 truck lock in and out only when it senses one wheel spining or are both wheels locked all the time? The only reason I asked about these is I was told the S-10 is a good rear for T's as opposed to a 9 inch because the 9 inch has an offset pinion or center or something like that? Then another thing I read said the 66-77 Bronco 9 inch rears were center pinion and were good for T buckets. I just figured take the path of least resistance and get one out of an S-10 if they work because they seem to be everywhere.
  10. dreracecar
    dreracecar
    from so-cal
    Pretty much all rear ends that are commom to what we install them in have the pinions midpoint of the housings and the ring gear is offset, except the front diff's on a four wheel drives. If you want the rear cover centered then one must cut the axle tubes and rework the axles and run the drive shaft at an angle.
  11. S10’s came with several different rear axles that were all “ten bolts”
    The S10 came with a 7.5”, 7 5/8”, 8.5”, or an 8.6”. S10 crewcabs with the 7 5/8” axle and S10’s with the 8.6 came with rear disk brakes. No matter which axle you got, there were only two variations, open or the G80 code gov' lock by eaton.
    The way these work is that the wheel with the least amount of traction gets the most torque until the the rpm difference between the axles is great enough to flip the lock out. It's a Cheasy rinkydink little dealy that wears out.
    That's all you can get from the factory. You can instal a locker as easy as changing the spider gears. Or get a different carrier
  12. gwhite
    gwhite
    SUPER MODERATOR
    If you want off-the-line acceleration, go with lower (numerically higher) gears. The 3.73 is a great all-around performer.
  13. dreracecar
    dreracecar
    from so-cal
    Kind of cramped, but I will try anything once---Opps, just re-read the ***le
