Posi Rear end
Discussion in 'The Hokey Ass Message Board' started by Wicked50, Feb 27, 2010.
  1. Wicked50
    Wicked50
    How do you ID a generation 3 camaro rear end out of a '87 Camaro with 3.23 gears. Numbers on the pumpkin are GM N 225226/6
  2. Wicked50
    Wicked50
    Just by looking at it I think is a 7.5" are these good can they handle a 350-400hp engine
  3. 40hemicpe
    40hemicpe
    from anaheim.ca
    they are not that strong...
  4. Wicked50
    Wicked50
    I have a good chance of blowing it out with a 401 nailhead and heavy foot
  5. 40hemicpe
    40hemicpe
    from anaheim.ca
    yup...
  6. Fat47
    Fat47
    I believe they are "limited slip" rears.
  7. Wicked50
    Wicked50
    So now I am looking for a 10 bolt 8.5" out of a camaro anything else that came with these?
  8. 40hemicpe
    40hemicpe
    from anaheim.ca
    what kind of car are you putting it in?
  9. hotflint
    hotflint
    there were 8.5 inch rear ends in 7r2 s10s posi
  10. 40hemicpe
    40hemicpe
    from anaheim.ca
    if its going in a early chevy 70"scamaro/firebird and nova will work
  11. Wicked50
    Wicked50
    its gonna go in my '50 chevy 3100
  12. GasserDave
    GasserDave
    from Sin City
    Run it till it breaks then put a real rearend in it..I think the rear ends are good for 300 real hp. If you hook up, its a gonner..
  13. Wicked50
    Wicked50
    Thanks Dave, I feel with a 401 Nailhead theres gonna be a lot of hooking up being had.
  14. Wicked50
    Wicked50
    Someone recommended using a ford 8.8"
  15. Deuces
    Deuces
    All my fords (3) have the 8.8 with the same 3.55 gear set. Next best thing to a 9 inch!!
  16. Wicked50
    Wicked50
    Damn if I go with 8.8 I am gonna have to exchange my front rotors as they are 4.75 bolt pattern. This is something I am gonna have to think about.
  17. Wicked50
    Wicked50
    Is there a kit that you can buy to change the 4.5" bolt pattern on Ford 8.8" to a Chevy 4.75" Chevy bolt pattern?
  18. Impalas chevelles biscains come to mind.
    Even the bigger 10 bolt is not really a high zoot rear. I would look for a 12 bolt unless your car is pretty light.
  19. Wicked50
    Wicked50
    its only a truck
  20. indyjps
    indyjps
  21. sdluck
    sdluck
    8.5 are very good.some time back a read that a guy was swapping ford and chevy axles in rear ends.He would match the spine and length.Not sure about bearings
  22. Truckedup
    Truckedup
    A carefully ***embled 10 bolt 8.5 inch will handle drag slicks and 500 hp.A 12 bolt is a little stronger and a lot more expensive to buy as an ***embly.....
