positive to negative ground
Discussion in 'The Hokey Ass Message Board' started by wdoland, Aug 8, 2013.
  1. wdoland
    wdoland
    from Virginia
    Would like to convert my 47 Chrysler Windsor over from positive ground to negative ground. From what I've been reading, it doesn't take too much. Reverse the ammeter gauge wires, reverse the wires on the ignition coil, polarize the generator and reverse the battery cables. There is no modern accessories in the car now. Changing would allow me to have a radio, even if it is with a 12 to 6 volt converter. (Keeping the car 6 volts)
    I just wanted to run it by the more experienced people on here to see if I'm overlooking anything.
    Thanks
    Wayne
  2. Mike51Merc
    Mike51Merc
    Change all the light bulbs.
  3. hotroddon
    hotroddon
    The light bulbs don't care if it's negative or positive ground.
  4. hotroddon
    hotroddon
    the coil - you do NOT reverse the wires. + is still + and - is still -. You leave the - side alone, it should only be going to the dist/points. The + side you need to change from going to the ch***is to going to the IGN term on the ignition switch.
  5. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Quote:
    He was probably thinking that he was switching over to 12v.
  6. Leviman
    Leviman
    No, light bulbs won't matter. You'll have to rewire the solenoid and the motor part of your starter though, they will run in reverse otherwise. Thr radio won't work backwards, might even damage something or catch on fire. Like you mentioned, ammeter will be out of wack. That's all i can think of off the top of my head. Relays might need to be rewired too.
  7. wdoland
    wdoland
    from Virginia
    There's also a solenoid and/or relay on the transmission. It's a fluid drive.
  8. SMOG_GUY
    SMOG_GUY
    from Dinuba
    The starter doesn't mind the change in polarity. Coil has to be neg side to dist (points) and pos side to ignition switch.
  9. R Pope
    R Pope
    Starters don't care about wrong grounds. Neither do relays and solenoids. Electrical gauges might not work, though.
    If all you want is a 12v radio, well, most radios have a ground wire and a power wire, just hook the ground to power and the power wire to the ground, coming off whatever you have for a 12v converter, and keep it positive ground.
    I should say, newer starters with permanent magnet fields will turn backwards with the wrong polarity. Not a problem on the older cars.
  10. Leviman
    Leviman
    I can't imagine the starter working with a swap of current. If it runs backwards or actually it won't run at all, as the solenoid will **** 'in' instead of out. I will say i told ya so so hard.
  11. Mike51Merc
    Mike51Merc
    Yes I was. Knee-jerk reaction to polarity change. The one usually goes with the other.
  12. 40FordGuy
    40FordGuy
    A question..... if you're keeping the 6 volt system, then why change the polarity ?
    4TTRUK
  13. badshifter
    badshifter
    You are wrong, so so hard. A non permanent magnet starter will only spin the direction it's built to spin. Regardless of polarity.
  14. mike in tucson
    mike in tucson
    from Tucson
    But the light bulb sales guy said I need to change the light bulbs?
  15. OldFord39
    OldFord39
    from Monroe, Wi
    To reverse a starter motor you would have to reverse the current going through the field windings; since you are reversing both the field and the armature current (so to speak) it should run in the same direction. Being positive ground or negative ground will make no difference. I totally agree with badshifter.
  16. scottb356
    scottb356
    I did this switch on my old 51 Lincoln without altering the starter. The first time I hit the ****on, it turned over VERY slowly and odd sounding ( I'm guessing backwards, despite what others are saying ) and stopped working with a puff of smoke and the stench of burned electronics. Prior to switching to a neg ground it had worked flawlessly.
    Take that for what it is worth.
  17. dtracy
    dtracy
    Scott356 - It wouldn't turn backwards because the starter bendix would just free wheel.
  18. DWest
    DWest
    from Missouri
    I think the direction a starter turns is determined by the position of the brushes. When I was racing karts we used old Ford starters to get them going, we just rotated the brush plate until it ran in the reverse direction, re-drilled the plate and bolted it back together.
  19. terrarodder
    terrarodder
    from EASTERN PA
    The starter on my 48 Studebaker ran fine even when I changed polarity anr ran 12 volts. The 6 volt coil burned out real quick when I left the key on, though.
