Event Coverage Post holiday "Meltdown" is coming...
Discussion in 'The Hokey Ass Message Board' started by Hot Rod Brando, Dec 21, 2025.
  1. Hot Rod Brando
    Hot Rod Brando
    Midnight Jan1st, after recovery from the night before, gates open for registration... Plenty of good times getting ready, prep is well under way. Stay tuned for updates as time progresses and all the excitement builds. We have quite a list of clubs and organizations that are planning on being part of the show... working on some top secret VIP guests, and a Thursday night pregame for the participants...
    Meltdown #10 July 17&18 2026 Pre-registration and criteria information
    The Vintage Drag Racing Foundation (501c3) strives to preserve the historic nature of drag racing events like Meltdown 10 and The Fall Out. We ask that participants endeavor to make their ride of choice look and feel like things were in the mid 1960’s and earlier. We get asked why a lot, and the simplest way to explain it is you cannot go to a Civil War enactment and expect to participate with a replica M1A or M16 and digital camo. The most accurate and tasteful vehicles will be selected first. Visual appearance is the top criteria. Fastest ain’t baddest when it comes to selecting the field. Whether it’s an 8 second G***er or a 15 second ride, it needs to look the part. Brandon, Paul, Smokey, and the rest of the Meltdown Crew look forward to seeing all our race family soon. In the meantime, get your ride done, the bugs worked out, don’t break anything major before July, and God bless you, your family, and the USA!
    Pre-Registration is required for this event and it opens January 1st 2026 at 12am.
    Do not try to register before that time. Bragging rights for those with the quickest registration submission.
    Racers must submit pictures of the car as it will be raced, clearly showing wheels, engine, and exterior of the car. Again, the images submitted must show the car AS IT WILL BE RACED. Bad pictures could delay or prevent processing of registration.
    We anticipate filling up to 500 race cars very quickly. The selection process will be based on criteria, overall look of the vehicle, & order of the entry received. We reserve to right to change and modify the selection process, and the criteria to race. These are all our vision for the event and do not 100% follow any rulebook.
    Please include the following information:
    Name:
    Address:
    Phone number:
    Year, make, model of car:
    Width of rear tires (contact area where slick meets the track)
    Cl*** and approximate E.T.:
    Club affiliation in any:
    Length of truck and trailer
    Email to: meltdownten@gmail.com (note the updated address for registration)
    If you have questions, Please email meltdownten@gmail.com
    MELTDOWN 10 RACE CRITERIA
    This event is recreating a 1960's drag meet. From the stands it will look and feel like a trip back in time. Does your car look like it came from the 60's? If you had a black and white photo of it, does it look vintage? If yes, then WE WANT YOU!
    WHEELS Must look like a style available in 1966
    -NO Weld Wheels -NO Center Lines
    -NO Pro Stars -NO Super Tricks or other billet wheels that came after 1968 -No bead locks
    EXAMPLE OF WHEELS THAT ARE ACCEPTED
    -GM Corvette rallys -Torque thrust D
    -Torque thrust originals -Aluminum slots -Factory steel wheels
    -Keystone -Rocket racing launcher
    -Cragar SS -Chrome Reverse
    TIRES
    -12" max width on door cars.
    -NO white or yellow writing lettering on tires or slicks. M/T is ok (MUST be black wall or era appropriate whitewalls)
    -NO Pro street type cars with huge rear tires. We're trying to keep tire sizes appropriate to 1966 sizes.
    SUSPENSION AND DRIVE TRAIN
    -Straight axle front suspension, -Stock front suspension, ball joint extensions are allowed with correct stance
    -No round tube ch***is full bodied door cars
    -Trans brake and line lock are allowed
    -Wheelie bars should not exceed more than 12" past rear bumper
    HOOD SCOOPS -Era correct scoops are permitted
    -NO cowl hoods -NO snorkel scoops
    -NO L-88 scoops -NO bubble scoops (teardrop scoops from the era are fine)
    ENGINES
    -All modified engines require a diaper per track rules
    -NO Nitrous
    -No anti-freeze in cooling system
    -NO LS Motors -NO Billet Valve Covers (unless hood remains closed, not on display.
    -NO Pro-Chargers -NO Turbos -Era correct Paxton ok
    BODY PAINT
    -No rat rods
    -No 1980’s and 1990’s graphics
    -No rusted cars (full panel rust)
    -No multi-colored panels (ex. yellow hood/green doors and red fenders) unless approved.
    -No modern decals all over the car
    -exceptions will be considered for original cars with do***ented history.
    GL***
    -NO riveted in windows or windshields unless fasteners are hidden or camouflaged.
    ELECTRONIC DEVICES
    -No 2 steps/stutter boxes that you can hear popping
    -No throttle stops
    SAFETY
    -Diaper required on 11.00 and faster cars per Byron Dragway track rules
    -Before racing starts check for oil leaks, fuel leaks, current seatbelts
    - Snell SA2020 or SA2025 NHRA approved helmets.
    -All vehicles must comply with NHRA safety rules concerning equipment, specific to ET and cl*** “modern” specs. Track rule or NHRA rule that is most stringent applies. Safety is a #1 concern for the driver, fans, and track crew. The added benefit is that it minimizes track down time. There will be a limited amount of diapers available to the track, but you have all read the rule, an no car will be entered that doesn’t comply.
    EXAMPLES- driveshaft loops, ****ter shields, roll bars, remote power disconnect, etc
    -ENGINE COOLANT MUST BE WATER!! -NO ANTIFREEZE!! IT WILL BE CHECKED
    RACE CL***ES
    -We will run heads up Sportsman tree. We will run 1/4 mile unless a group is specially designated and pre-approved 1/8 mile. All 1/8 mile will run as a group but must be pre-approved so as to coordinate with the tower.
    DRAGSTER & ALTERED CL***
    -Can be an original or re-created ch***is, but must appear as cars in the 60's would have looked. Larger rear tire width ok
    GAS Cl***
    -A 9.99 and faster
    -B 10.0-11.0
    -C 11.0-12.0
    -D 12.0-13.0
    -E 13.0 & slower
    -Do not enter a cl*** where you cannot consistently meet the ET minimum. Remember, in the 60’s, B, C, and D were the most compe***ive cl***es, and due to cubic inches much to weight cl***ing, were many times much faster than A. Pick the right cl*** so we put on a good show.
    -Blown and unblown in same cl***
    -A/FX and F/X (1960 to 1966 cars with straight axles and altered wheelbase)
    -Stock (any year up to 1966) • May have headers • Full interior
    -Super Stock (select 1961 to 1966 cars with stock front suspension)
    -Hot Rod- street rods & hot rods (Pre 1961 cars/trucks that do not fit gas/stock cl*** rules)
    -Car must be a traditional style hot rod
    -NO RAT RODS
    -No mustang II front ends exposed on 30’s style cars
    MOTORCYCLES
    All bikes must appear to be 1966 or older and adhere to Vintage Motorcycle Racing Club safety rules.
    ACCEPTABLE MODEL YEAR AND EXCEPTIONS:
    -1966 and earlier only, exception being body style change such as:
    -1966-1967 Chevelle -1966-1967 Fairlane
    -1966-1967 Falcon -1966-1967 Mercury products
    -1966-1967 Nova
    -NO 1967 Firebirds or Camaros
  2. QTP
    QTP
    from Moore, SC
    We will be there!
    mad mikey, Sharpone and chryslerfan55 like this.
  3. For those about to rock, we salute you.
  4. Hot Rod Brando
    Hot Rod Brando
    Wheels!!! we want Wheels!!! :)
  5. Ryans65
    Ryans65
    from Yulee FL
    Excuse me if I missed it in the post but where is this event being held? Sounds like a lot of fun to watch!
  6. Someone better post pics,please, cause there's gonna be some real cool cars by the sounds of it:cool:!!
  7. Adriatic Machine
    Adriatic Machine
    Just exit your front door and take a step back in time! Can’t miss it!
  8. Budget36
    Budget36
    I read about following “Byron Dragway rules”. I’d ***ume that’s where it will be held.
  9. Hot Rod Brando
    Hot Rod Brando
    It's in Byron Illinois. Our 10th running...
    mad mikey and Sharpone like this.
  10. Hot Rod Brando
    Hot Rod Brando
    Here's some from the past events.... Check out the p***enger in the King Braeger Chevy... 549976794_10240044024188029_4536967213121363724_n.jpg 554101419_1379880869956198_1890725086525558040_n.jpg 592898545_25683177501267290_338004628369954749_n.jpg 593583286_10243074149056378_7792562801226714751_n.jpg 594974101_25722282234023483_8091541447969842894_n.jpg 595707210_860672196544340_3986305980451706865_n.jpg 596413073_10240242120900785_8020827369772456468_n.jpg 600318140_10235586351694370_2101219112320260649_n.jpg 601970959_10235586373014903_7567425890870632943_n.jpg
  11. pnevells
    pnevells
  12. pnevells
    pnevells
    Got mine in at 12:10 AM , received a confirmation email already, now we wait........
    mad mikey and Tickety Boo like this.
  13. Greg Rogers
    Greg Rogers
    This is cool, can I come with my '56 F100 and just hang out and watch? Any camping available near?
  14. pprather
    pprather
  15. rusty1
    rusty1
    ^^^I talked to Paul Zielsdorf last summer, our club, the Tin Butchers, are parking the swapmeet vendors again, and the car show should be right next to the swap.
    there is camping close to the show & swap areas.
  16. Great pics guys,thanks for sharing!!
  17. Greg Rogers
    Greg Rogers
  18. wrenchbender
    wrenchbender
    I will be there with the “poison Iveys dodge” afx car cant wait oh im in by the way how bout the rest of you guys
    powrshftr, Tickety Boo and mad mikey like this.
  19. pnevells
    pnevells
    We made the cut #79
  20. Greg Rogers
    Greg Rogers
    Wow 3 different threads about Meltdown 10! I hope i can come as a spectator.
