POSTING PICS
Discussion in 'Questions & Suggestions' started by doug3968, Oct 30, 2018.
  1. doug3968
    doug3968
    having problems posting pics, just tried with "Brookville, Pa barn," is it OK if I delete my post if the pics do not show on the site? Dealing here with info on Windows 7 and new computer is Windows 10. I don't want to clog up the site with attempts to display pics. Doug
    Stogy likes this.
  2. Stogy
    Stogy
    Doug you can edit your post and delete the pics that didn't work and upload the new pics...are you using Photobucket? Why I ask is that site is a major pain in the rear...
    I use .jpeg/.jpg format for pics.
    I load my pics from my computer and generally have no issues. I try to keep them between 300 to 400k in size.
    If all else fails yes you can delete your old post and make a new one however it will not be in the position of your deleted post.
  3. 73RR
    73RR
    Can you offer some details on how to upload from my desktop? Use a PM if you want.
    Stogy likes this.
  4. Stogy
    Stogy
    I will go through loading 2 Pics through the steps I take...follow the Blue Arrows note Clic or Select is the same action...it is pushing the left mouse ****on once = Clic or Select
    Step 1; Clic or Select UPLOAD A FILE
    Step 2; Find your folder were pics are and hold Control Key at bottom left corner of keyboard (marked CTRL) down and Clic or Select Pic 1 & Pic 2 then release CTRL
    Step 2 contd... When you select them the pics will become Highlighted and you will see the 2 file names in the File Name area...see below and then Clic or Select Open
    Step 3; If you have Text or a Quote you can click in the Post Area where you want your pic to appear...I chose below the Quote in this case (See Blue 1 below) You will see a flashing line near Blue Arrow...
    Then Clic or Select FULL IMAGE (See Blue 2 below) and your first image will show up in Post Area...
    Now before you add the second pic hit Enter on your keyboard twice to create a space between the 1rst & 2nd pic...
    Now Clic or Select FULL IMAGE (See Blue 3 below) and your 2nd image will show in the Post Area...Then select POST REPLY
    After your done it should look like this...below...
    ClayMart likes this.
  5. Stogy
    Stogy
    lothiandon1940 likes this.
  6. 73RR
    73RR
    Very much appreciated! I'll give it a go.
    Stogy likes this.
