Powder coat intake manifold?
Discussion in 'The Hokey Ass Message Board' started by 36tudordeluxe, Mar 12, 2013.
  1. 36tudordeluxe
    36tudordeluxe
    Am wondering if powder coating my Edelbrock intake manifold for my 8BA would be okay as far as the gasket areas are concerned where carb. spacer mates to intake and bottom side of intake where it mates to the block; in other words can any gasket surface be powder coated? The gaskets will be used dry without any sealer.
  2. 325w
    325w
    A good powder coat company will not coat the gasket surface unless you ask them to. I would keep the gasket surface as is.IMHO
  3. kracker36
    kracker36
    I own a coatings business and prefer ceramic coatings on intakes because of how thin it is applied. Plus, its chemical resistant. I would not powder coating the mating surfaces however. PM me if you have any questions. --Lee
    Nailhead Jason likes this.
  4. never coat the mating surfaces .
    they should always be taped off with high heat tape and all threaded holes plugged w/ silicone plugs etc etc
  5. elba
    elba
    Carefull what kind of cleaner you use on it. Made mine go from shinny to dull.
  6. 36tudordeluxe
    36tudordeluxe
    Thanks everyone for responding, I'll leave the mating surfaces alone.
  7. kracker36
    kracker36
    That is whats nice about my ceramic coatings. No masking is required and chemicals will no remove or discolor it like powder. Powder is really not a lot different than paint.
  8. GOATROPER02
    GOATROPER02
    from OHIO
    We have a lot of manifolds ceramic coated because its very durable to heat and fuel......and if done correctly....it can be media blasted and made to look like cast aluminum....
    Tony
  9. Blue One
    Blue One
    from Alberta
    And that Tony makes absolutely no sense at all. :D
    Especially when you consider that you can buy Cast Aluminum finish powder coat.
    http://www.eastwood.com/hotcoat-powder-cast-aluminum.html
    It makes no sense at all to powder coat something and then blast it :rolleyes:.
  10. kracker36
    kracker36
    I have a ceramic coating called cast aluminum. Powder coating on an intake is asking for trouble if gas gets on it a lot.
  11. GOATROPER02
    GOATROPER02
    from OHIO
    I said ceramic.... Not powder....get fuel and a little age on your powdercoat and then get back to me.
    We sometimes are going for a certain look and texture on a build....to keep an as cast feel for the part....
    1927graham and Nailhead Jason like this.
  12. they do make a fuel resistant high gloss clear powder just for this application, I do tons and tons of engine parts and never have any issues.
    and as far as age goes with powder, now a days the technology in powder is far superior to old stuff, millions of colors and crazy durable in many different ways. Its a different powder world than it used to be.
  13. denis4x4
    denis4x4
    from Colorado
    This Stromberg-Bendix manifold was powder coated eight years ago and has held up just fine.
  14. CutawayAl
    CutawayAl
    from MI
    Compared to the standard polyester based powder coating that's used for most things, epoxy based powder coating is more resistant to solvents, chemicals, fuels. However, it doesn't tolerate sunlight as well, so in cars with open engines the coating would slowly fade/chalk over time.
  15. Stevie Nash
    Stevie Nash
    Always wondered, can powder coating be matched to a paint code? I need some wheels done the color of the truck.
  16. numbers dont cross reference but there is a **** ton of colors available. look at www.prismaticpowders.com they have a user friendly browsing site and they are a NIC company, great powder! no affiliation with them, just use their products.
    ppg also has a powder department, maybe they created a system where theirs cross reference to their paint codes, I dunno.
  17. GOATROPER02
    GOATROPER02
    from OHIO
    Id like to know more....
  18. Roothawg
    Roothawg
    I know this is an old thread, but I am curious about home units. Are they capable of doing piece parts like intakes etc. or would you be better served to hire it out? I want a super smooth finish and I don't know if I can obtain the results I want with a hobby DIY setup.
  19. Nailhead Jason
    Nailhead Jason
    I had no problem with the Eastwood powder coat set up I have. worked fine for a small chevy intake. but I only did that part in the oven at that time since it took up so much space. It worked great on small parts and brackets especially, just because of the size and being easier to handle getting it into the oven. Just don't do it in your home oven! get a cheap or free one from craigs list and keep it in you shop. Supposedly it can make food you cook in the oven afterwards toxic. Didn't feel like taking that risk.
  20. Roothawg
    Roothawg
    That's the kit I was looking at.
  21. indyjps
    indyjps
    I had an intake powder coated and the coating cracked. It's an isolated instance and your results may vary based on the coater, powder etc. Use a good known coater. My intake now looks like **** and getting the powder off is going to be a pain.
  22. Nailhead Jason
    Nailhead Jason
    Between the one that I coated and the dual quad intake that we had ceramic coated, the ceramic coated intake on the roadster looks much better. After a year of daily driving about 10,000 miles the clear powder coated one started cracking and staining. it looked real good for about 9 months, then just starting looking like **** fast. If it is for something that is not driven all the time it would probably be fine for a long time. But I beat my 64 Buick up and down 95 here in VA back and forth to 125 miles to DC everyday. Heat takes its toll with that stuff. But that being said It still looked great on all the brackets and such that I used it on just not the intake so much. Also, im just some jack *** doing it in my garage so a pro shop would probly have a better finished product than what I did. I still like the ceramic coating the best.
  23. Roothawg
    Roothawg
    I have had a few ceramic coated. I wish there were colors in the ceramics.
  24. Blue One
    Blue One
    from Alberta
  25. Nailhead Jason
    Nailhead Jason
    The only colors I have seen in person are silver black and white. All look good to me. Im planning on getting some headers white soon.
  26. hotroddon
    hotroddon
    I have had a few sets of headers Ceramic Coated in White - NONE of them have held up worth a damn so far!
  27. Roothawg
    Roothawg
    Yeah I heard they have to ceramic coat then powder over that. Not sure if that is true or not. Intakes won't have nearly the heat that exhaust do, but I like painted intakes that match the block color, that's why I am inquiring about colors.
    Blue One, I saw that on the web, but I was wondering about durability.
  28. Blue One
    Blue One
    from Alberta
    Not sure on the durability I know that the silver ceramic is very good and stands up well.
