Projects Powder Coat Removal
Discussion in 'The Hokey Ass Message Board' started by strombergs97, Mar 23, 2010.
  1. strombergs97
    strombergs97
    Help, I got some 97s to rebuild and the person had them powder coated and got it on the flange face..How do I remove just on the flanges..I tried to s****, didn't work well.. This has to be the worst powder coating I've even seen. Six 97s that look bad..
    Thanks
    Duane.
  2. Probesport
    Probesport
    Razor blade and a heat gun are how I have always done it.
  3. HOTRODPRIMER
    HOTRODPRIMER
    It's going to take sandpaper or a file.
    I recently had my exhaust manifolds powder coated and the flat mounting surface had big globs of powder coat much like runs in paint,,,I used a grinder to remove the offending material. HRP
  4. 51 Leadsled
    51 Leadsled
    from NC
    score a line with a razor blade or file a border around the area to be cleaned off to reduce the chance of large flakes poping off first then go at it.
  5. cadillacoffin
    cadillacoffin
    if it was done right it will not peel. we use a very high temp oven to burn pc off,....
    there are chemicals like zip strip that will take it off. other then than, blast, sand, file.....
  6. dirtbag13
    dirtbag13
    X 2 on the burn off ! our local powdercoater here puts the parts into an oven and burns the powdercoat off then a quick blast with a powerwasher and its clean metal once again !
  7. zzford
    zzford
    I'd use an air-hatchet. It'll remove 'bout anything.
  8. Ayers Garage
    Ayers Garage
    When I screw up a coating job I either super heat it in the oven or char it with a torch. The heat kills the powder and it comes right off.
  9. belair
    belair
    Air hatchet-I gotta get me one of them.
  10. vtwinpartss
    vtwinpartss
    from NOR CAL
    Aircraft stripper works, it works even better if part in heated a little.
  11. CyaNide
    CyaNide
    from Texas
    regular paint stripper will work too, you will have to let it sit for a while and then it will peel like regular paint
    CN
  12. tedsrodshop
    tedsrodshop
    I use Jasco epoxy stripper and a heat gun .
  13. redo32
    redo32
    I wouldn't recommend a burn off oven or heating with a torch. That carb is made out of zinc that melts at about 800 degrees. Burn off ovens run between 600 & 700 degrees. Even if you don't melt it it will probably sag. Use the brush on paint remover. If your just trying to clean up the gasket surfaces, what you can't get with a razor blade, you might have to use a small dremmel tool. Have fun!!
  14. pigpen
    pigpen
    from TX USA
    Worked well for me also. :) pigpen
  15. chopped 35
    chopped 35
    from australia
    air hatchet................that'l learn it good.......:eek::eek::eek:
  16. bbc 1957 gasser
    bbc 1957 gasser
    powder melts at 400 degrees hows that going to work .?
