Technical powder coat
Discussion in 'The Hokey Ass Message Board' started by nunattax, Feb 14, 2015.
  1. nunattax
    nunattax
    any problems with powder coating rad tanks alloy rad.powder coating oven heats to 200 c 392 f
  2. I would think that the thickness of the powder coat may hinder the cooling capabilities of the radiator if you did it to the fins.
  3. Had my new aluminum radiator powder coated black satin, cools perfectly.
  4. There was a cooling problem mystery thread a while back. His radiator was powder coated and hindered cooling.
    Might be different with just the tanks though.
  5. The37Kid
    The37Kid
    What is the reason for it? Bob
  6. nunattax
    nunattax
    well im going for a blackout finish on the truck and the rad stuck out too much.it looked too modern on an old truck.i can see it through the grille(that is black too.)i was thinking of just doing the tanks.ive sprayed the core/fins with high temp paint done the mounting brackets and the fan shroud.the tanks would finish it off. nosejob 008.JPG
