Projects Powder coated brake drums
Discussion in 'Traditional Hot Rods' started by Sweet & Low, Jun 30, 2017.
  1. Sweet & Low
    Sweet & Low
    Have any of you guy's Powder Coated your early Ford (I have 1940) brake drums?
    I thought it would be easier to maintain w powder coating but I'm not sure how they will dissipate heat if powder coating.
    Any of you guy's tried this?
  2. VonWegener
    VonWegener
    I would not worry about it. I had brake fluid shrinkle up the powder coating on a backing plate once otherwise no problems.
  3. denis4x4
    denis4x4
    from Colorado
    Powder coated the early Ford drums on the Zipper 19 years ago and they still look good
  4. steems
    steems
    Powder coated mine. Would recommend it.
  5. krylon32
    krylon32
    from Nebraska
    I powder coat all the drums on my builds. I powder coat the entire drum and then take it to the local brake shop and they turn the coating off the braking surface. It takes a little extra effort but I think I get a better job.
  6. Schwanke Engines
    Schwanke Engines
    We just put Painters Tape on the Brake Surface, and then Run them through the line with the rest of our parts. Works great.
  7. bondolero
    bondolero
    Yep, real pretty.
  8. And have the backing plates done at the same time. If you need to fill any 'pits', there are fillers that are designed for high heat.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Not a problem dissipating heat, the curing process subjects most parts to 200 degrees for anywhere from 10 to 30 minutes. HRP
  10. Sweet & Low
    Sweet & Low
    Thanks Much guy's, going to the brake shop this morning to get new linings matched to the drums and then off to the powder coaters.
