Hot Rods Power Glide Transmissions
Discussion in 'The Hokey Ass Message Board' started by pirate, Nov 17, 2022.
  1. pirate
    pirate
    from Alabama
    Talked to a guy with a T Bucket for sale. It had a old school 283 Chevy with a Power Glide. What is the good, the bad and the ugly on a Power Glide?
    dana barlow and 1949*john like this.
  2. KenC
    KenC
    ***uming it is an aluminum model: Pro, light, simple, rugged. Con, two speeds. All in all, a decent choice for a light weight car with plenty of torque.
  3. squirrel
    not enough information....could be cast iron, could be aluminum, could be all stock, could be modified, who knows?
    But as much as you're likely going to drive a T bucket, it probably doesn't matter much.
    rockable, mad mikey, jimgoetz and 2 others like this.
  4. williebill
    williebill
    Friend had a 57 convertible when I was in HS, and he ran the hell out of it all the time. Wound out 1st to ungodly RPMs, and hit 2nd hard every time he drove it, never missed a lick. We got used to hearing that little 283 screaming in 1st, never was a problem. In a car as light as a T, I don't think it'll matter only having 2 speeds.
    mad mikey, Rolleiflex and LOST ANGEL like this.
  5. jaracer
    jaracer
    The aluminum Powerglide is a darned good transmission. The only "problem" is that they are only two speed. However, Chevrolet sold millions of cars with Powerglides and most people didn't mind the two speed thing. When I taught automatic transmission rebuilding, I always started with the Powerglide as it is a very simple transmission.
  6. When I was bracket racing, the rumor was a car under 3000 pounds was quicker with a Glide than with a 3 speed automatic.
  7. NoelC
    NoelC
    Isn't that something. I heard the opposite. What the heck.
    Rumor has it I've been wrong before.
    All those who pulled out a perfectly good transmission to get an extra gear that you didn't need, or fully understand at the time what it was doing for you, or not, raise a hand.
    Talk about brain washing. It was turbo 350 or nothing. Hot rodding 101 was upgrade. Glides were s**** metal.
    It sold the 1/4 mile business model of seconds counting. And they do. But that's where the lines crossed. Not so much these days.
    There is really no good bad or ugly. But good, It works or it don't. The bad, compared to a modern transmission, extra gears and expense when fixing.
    But if there is an ugly, it's hammering on the gas pedal looking for speed, there is nothing to kick down to for gears, and the 283 wasn't built with the high reving balls to p*** that semi while driving up the grade they call a hill.
    ekimneirbo and Truckdoctor Andy like this.
  8. 38Chevy454
    38Chevy454
    The reason a PG is faster in a <3000 lb car is because one less shift and also less blowing off the tires at the line. With modern high stall torque converters being very effective at torque multiplication a lower 1st gear is not required.
    Back to original question. A light T bucket will do fine with a PG. Just hope it's the aluminum version, not the old cast iron.
  9. squirrel
    The old cast iron version will work fine, too, until it doesn't, and then it'll be "fun" to get it fixed. It's not real difficult, just kind of strange, the way it's built. Did my first at age 16, it worked better when I got done with it (second gear went away, as the drum bushing wore out, and it needed a new valve body to fix it)
    1949*john and Truckdoctor Andy like this.
  10. Moedog07
    Moedog07
    We had a Super Gas car in the 80s that ran a 440 Mopar backed by a Powerglide. Good set up in that capacity. It got "stressed" regularly and was vary reliable.
  11. Ran glides in all my tbuckets, pretty much idiot proof(that means it survived me). Even ran a trick one in my Supermodified, minus torque converter. Nice weight saver.
    Driver50x likes this.
  12. Brian Penrod
    Brian Penrod
    The over under 3000 lb thing was due to available gearing at the time. Glides had a 1.76 low gear, iirc, later aftermarket lower first gear ratios became available, so heavier cars started using them.
  13. 38Chevy454
    38Chevy454
    V8 PG used 1.76 first gear. 6 cyl PG used 1.82 first gear. Otherwise essentially the same. But agree aftermarket lower gear are available as well.
    In my OT drag car ( no longer have) i ran 1.82 PG with a BBC. Hardened 300M input shaft and turbo spline since i had THM converter. Also went to trans brake in PG. Replaced T350 since i was breaking them. Never broke the PG.
    chicken, Hnstray and osut362 like this.
  14. Bleach
    Bleach
    I drove a ‘62 Nova with a 6 and PG a few times back in the early ‘80’s. It was a dog compared to my OT Ford with a 200 6 and C4.
    low down A likes this.
  15. sdluck
    sdluck
    I know this might be off topic,but Jim Hall of Chaparral fame ran a few in his race cars,don't remember trans failure.
  16. Dooley
    Dooley
    from Buffalo NY
    I have aluminum glide in my 36 and I can spin my tires whenever I want..
    With a manual shift I can hit 90 in first gear...I run 3:73 gears. I'd recommend that as well.
    Tow Truck Tom likes this.
  17. Harv
    Harv
    from Sydney
    Poor man's Lenco :D
    I'm running the 6-cylinder cast iron Slide and Glide in my I6 FED, as a shorty version. The only downside is that no-one makes an aftermarket input shaft for the 6-cylinder version (uprated aftermarket V8 internals otherwise fit). It has a short length of input spline (most of the shaft length is covered up in convertor boss). It should be good for around 400-500 ponies, but above that will run the risk of stripping those splines.
    Cheers,
    Harv
  18. lippy
    lippy
    from Ks
    Dooley, I had a 64 corvette coupe, it weighed 3,075 lbs. It was a stout 300 327 with a glide and 3.73's. It also would run 90 in low if you manually held it in and when you shifted it it would run like hell above a hundred mph I saw 130 on it many times. That's when it got front end light. lol. It had a B&M shift kit in it but was stock otherwise. Never got outrun by the muscle cars back in 72. Lippy
  19. HOTRODPRIMER
    HOTRODPRIMER
    A aluminum 2 speed power glide is great for drag racing, the 2 speed seems to lack something ,, that extra gear. HRP
    warbird1, Driver50x and ekimneirbo like this.
  20. v8flat44
    v8flat44
    I have a friend who builds aluminum Glides for dragsters in Ohio. Guys seem to love them.
    mad mikey and Blues4U like this.
  21. Dave G in Gansevoort
    from Upstate NY
    I considered one for the Whatever project, but then was given a T10 and a T5. Then I got T10 parts from Alaska, and another T5 local. But I'm still thinking that a 1.75 low pg might be a solution to space problems. Good to see some opinions...
  22. Roothawg
    Roothawg
    I had one in my bucket with a 283 and a 3.36 gear. It was great.
  23. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I made a T bucket friend at a show in Reno. He told me how he had become happy ( after trying other combos ) with a Pglide, 2500 stall converter, and cheater slicks.
    That is why I keep a Pglide in my garage. Some day...:rolleyes:
    The real question here is when do you plan to test drive it?
  24. bobss396
    bobss396
    My left nut still remembers the old iron units. I had the aluminum ones in more than a few cars and I liked them. The latest was in a '68 Impala that worked well.
    mad mikey likes this.
  25. Blues4U
    Blues4U
    from So Cal
    Probably more drag races have been won with a PG trans than any other model.
    My Model A pickup has a 283 & PG w/ 3.23 rear gears; it runs damn good on the street, I don't miss a low gear at all. The pickup only weighs 2160 lbs.
  26. 1971BB427
    1971BB427
    from Oregon
    A lightweight car like a bucket T is probably the only place I'd be OK with a Powerglide for a street car. I disliked those Powerglides back when I owned my first '57 Chevy in 1967, and was tickled when they came out with the TH350 and TH400 trans!
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That.
    And nine-inch Ford rear ends.
    I use PGs in my three drag roadsters. They can be made bulletproof. The best thing to ever happen to the Powerglide is the advancement of high stall speed torque converters. They will perk up the response of a PG when driven hard or will be very docile when driven relatively gently on the street. If I were to use one on a street car I recommend a stall speed of around 3000 RPM.
    mad mikey, wraymen and Blues4U like this.
  28. Truckedup
    Truckedup
    And a SBC engine......
  29. wraymen
    wraymen
    I have a crazy idea of putting one behind a 500 Cadillac engine in my slingshot. Your ideas and input would be highly appreciated.
    chicken, mad mikey and lothiandon1940 like this.
  30. theHIGHLANDER
    theHIGHLANDER
    You only need 2 speeds, FAST and FASTER...;)
