Technical Power master Flathead starters
Discussion in 'Traditional Customs' started by 50 Merc Man, May 20, 2024.
  1. 50 Merc Man
    50 Merc Man
    Alright my fellow gearheads, power master starters!!!! (****) . I’ve just lunched my third starter and for the life of me I don’t understand why or what the problem is. Is there any solution to this? Do I just go with an original starter or call and ***** out speedway performance? I’ve had it gettin underneath that big *** car every year or so
    Screwed!!
  2. Tim
    Tim
    from KCMO
    What exactly is it doing? What do the teeth look like?
  3. 50 Merc Man
    50 Merc Man
    I haven’t got underneath it yet brother, it’s making that all to familiar sound of the bendix engaging with a broken bendix spring. Just a piss poor design to begin with. Gonna try and get a hold of one the techies over at speedway and pick their brains to see if I have a different style starter option for flatheads
  4. lostn51
    lostn51
    from Tennessee
    What kinda Bendix does it have on it? If it’s like the factory style I know that the break about once a year or so. I’m looking for a good 12v starter for mine if I can’t find one I’ll put the new style bendix on the one that’s in there and use it as is.
  5. 19Fordy
    19Fordy
    Forget Powermaster . They are junk. Buy an OEM Ford starter with the Bendix drive.
    Even if it's used. Rebuild it and you will be a happy camper.
    Here's how I converted my 6V starter to 12V.
    It's a lot cheaper than buying a new starter.
    flathead starter motor - The Ford Barn
  6. 51504bat
    51504bat
    Van Pelt sells a 12 volt starter with a USA made Bendix.
    Tow Truck Tom and Okie Pete like this.
  7. lostn51
    lostn51
    from Tennessee
    I left mine 6v when I did the 12v conversion and the only issue was breaking the bendix. I drove it daily for several years before putting in the 347
  8. 50 Merc Man
    50 Merc Man
    Thanks gentlemen, can you tell me a little more about this van pelt starter?
  9. Budget36
    Budget36
    I believe they are referring to Mac VanPelt.
    Vanpeltsales.com
    rusty valley and Okie Pete like this.
  10. clem
    clem
    I broke 2 standard bendix’s before I learned to stop cranking the key until the starter/ring gear had stopped turning. ie , fully disengaged.
    Haven’t broken one since, about 15 years……..
    I think that it is a 6 volt starter, in a 12 volt 8BA.
    Have you checked that the starter lines up correctly with the flywheel when engaged ?
    Oneball likes this.
  11. 50 Merc Man
    50 Merc Man
    I will now, for sure
  12. 50 Merc Man
    50 Merc Man
    That van pelt starter , does it require some “modifications “ to get proper fitment? I’ve seen those advertised before and it’s said that you pull the starter plate off and grind off some of the casting. Sounds like an additional pain in the *** to me
  13. 50 Merc Man
    50 Merc Man
    Was also considering the Flathead mini starter with integrated solenoid. Anyone ever used one of those? IMG_8076.jpeg
  14. 51504bat
    51504bat
    Only if you use the "new" style enclosed Bendix. The one Van Pelt's sells has the original style Bendix. Fits with no issues. When my POS Power Master starter died for the second time I bought I new 12 volt starter from Joe's Antique Auto. His listing for the starter mentioned it came with the new style Bendix which I didn't want due to fitment issues. But Joe agreed to subs***ute an original style Bendix in place of the new style Bendix. The Van Pelt starter already comes with the original Bendix. As far as Power Master starter issues, the first time it broke I took it back to vendor who ended up repairing it on site instead of sending it back to Power Master under warranty. The second time it died they looked at it again and found it was not repairable. All the plastic gears inside were toast. YRMV
    alanp561 and 50 Merc Man like this.
  15. krylon32
    krylon32
    from Nebraska
    I must be the outlier, I've had 6 FH motors built for customers and I used Power Master starters on them plus a couple on my own FH powered cars and so far no problems. All of these cars had new brand name flywheels. Maybe my days coming?
  16. alchemy
    alchemy
    I’ve had the original 6V Henry Ford starter on my sedan since 2006. Works fine on 12 volts. And never broke a bendix either (knocking on wood).
  17. 50 Merc Man
    50 Merc Man
    Plastic gears!!! Wow think I’ll pull one of these apart and check that out. I have two to choose from now
  18. GordonC
    GordonC
    Running that stump puller from Speedway on my flathead and no issues. oh, oh, now I did it!
  19. Bandit Billy
    Bandit Billy
    I have a power master starter on my blown flathead for 5 years now, no issues.
    seb fontana and GordonC like this.
  20. 50 Merc Man
    50 Merc Man
  21. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I just use the original 6 volt starter on 12 volts. Haven't had a problem yet.
  22. 1935ply
    1935ply
    from peyton,co
    I had starter problems on my flathead with a stock ford starter. I was running the new style bendix and it would not always disengage and the starter would over heat, then the springs for the brushes would lose tension and then no start. Went back to the old open style bendix and never had another problem.
    50 Merc Man likes this.
  23. 50 Merc Man
    50 Merc Man
    On the stump puller starter your using, did you have to shim it or not?
  24. 51504bat
    51504bat
    The POS flathead Powermaster starter that I referred to in my earlier post was similar to an original starter not the newer high torque unit. No experience with the high toque version. original style.png high torque.png
    Bandit Billy likes this.
  25. 50 Merc Man
    50 Merc Man
    Thanks my Redlands brother! My parents lived there for many years btw. I did too actually when it was all orange groves. Beautiful!!
  26. GordonC
    GordonC
    No shims needed. Bolted straight in.
    50 Merc Man and sidevalve8ba like this.
  27. Bandit Billy
    Bandit Billy
    Ah, the one I run is the bottom one. I had a buddy run the one on top and he had nothing good to say about it.
    GordonC and 51504bat like this.
  28. shorrock
    shorrock
    I´m with Billy, have heard several complaints for the upper starter. The bottom one is working flawless on my two engines. The round flange allows to drill new fastening bores if the exhaust manifold is too close.
    Bandit Billy and 51504bat like this.
  29. 50 Merc Man
    50 Merc Man
    What length bolts are you using with that stump puller starter? 1 1/2” or 1 1/4” and you said you didn’t have to use a shim or spacer?
  30. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Built over 25-30-35 flathead engines for myself and others over a 60 year period. Not only did I NOT change a stock six volt starter over to 12 volts(waste of time—if your flathead does NOT start within 3-5 seconds of operator trying to start engine) u have something else wrong that a starter may or may not remedy.Yes,if u continually “crank” a stock six volt starter over15-20-30 seconds u may damage it. I have had stroked engine,supercharged engines,higher compression engines,multiple carb engines,etc and have NEVER,ever even considered anything but a stock six volt starter. IMG_2414.jpeg IMG_2411.jpeg IMG_2200.jpeg IMG_0322.jpeg IMG_0272.jpeg IMG_1943.jpeg IMG_1753.jpeg IMG_0848.jpeg IMG_0723.jpeg IMG_0649.jpeg
