Technical Power master Flathead starters
Discussion in 'Traditional Customs' started by 50 Merc Man, May 20, 2024.
  1. 50 Merc Man
    50 Merc Man
    Bolt size or length?
  2. 50 Merc Man
    50 Merc Man
    6 volt huh? No electrical issues or frying the starter?
  3. chicken
    chicken
    from Kansas
    The only negative about using the 6v stock starter on 12v is that occasionally the spring breaks on the Bendix. Not often, and the starter does just fine. They run years like this.
    S.E. SCHROER and alanp561 like this.
  4. 50 Merc Man
    50 Merc Man
    That’s what happened on the first stock starter I pulled off. I wanna say it was a 6 volt job too
  5. theHIGHLANDER
    theHIGHLANDER
    Amps matter most on motors. 6v on 12v can heat up as said above if they're cranked too long.
    gary macdonald likes this.
  6. 50 Merc Man
    50 Merc Man
    If your starter bolts are too long, would you hear a rubbing or clicking noise when depressing the clutch? I had no noise issues at all before changing out the starter and I don’t believe the bendix is not disengaging because in neutral there isn’t any noise at all. What do ya think boys?
  7. shorrock
    shorrock
    from Germany
    Neither - if the starter is too close you can rotate it away from your exhaust manifolds and drill new holes, not all the way around but several degr each way.
  8. MARKDTN
    MARKDTN
    On my 8BA I have stock 6V armature in a '63 390 Thunderbird case. That gets you the correct guts with a 12V wound stator. I have never broken a spring.
    Toms Dogs likes this.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    I ran a stock 6v on my 276 Merc the whole time I had it. Never had a problem.
  10. 50 Merc Man
    50 Merc Man
    Problem isn’t clearances, problem is when I depress the clutch it makes a rubbing noise, when not depressed, no rubbing noise
  11. shorrock
    shorrock
    from Germany
    Check axial crank play then.
  12. 50 Merc Man
    50 Merc Man
    ??? Ya gotta dumb it down for me boss
  13. distributorguy
    distributorguy
    from MN
    After having a rebuild company take my good Bendix and replace it with Chinesium (that also failed) I installed a high torque starter like I have on several other cars. I won't buy the Powermaster brand, but there are plenty of good ones out there. Not only has it been flawless for 5 years, but during that time I used the starter to move the non-running truck around my pole shed. If you get a good one, they're indestructible!
    leon bee likes this.
  14. 50 Merc Man
    50 Merc Man
    Thank you bro!!
  15. chicken
    chicken
    from Kansas
    See if the end play on the crankshaft is excessive, and the crank and flywheel are moving forward and rubbing on something when the clutch is used. Could be part of the starter, end of a bolt, anything the flywheel is close to. If you think a bolt may be too long, maybe put a washer on it and see.
    50 Merc Man likes this.
  16. 50 Merc Man
    50 Merc Man
  17. 50 Merc Man
    50 Merc Man
    Will do, thank you
  18. 50 Merc Man
    50 Merc Man
    Keeping in mind, up until I installed this gear reduction starter I wasn’t having any noise or rubbing sound at all with that POS power master starter. I’m gonna get underneath it again and rotate the starter around (right now it’s in the upside down position) to see if that’s what it might be. If not I’ll be kickin out another 2-300 bucks for a Van Pelt starter. Thanks again fellas for your insight
  19. Jim Mothershead
    Jim Mothershead
    Hey, Merc Man
    You will get nowhere "*****ing out" anybody. Ask for a Speedway tech.
    Three smoked starters say YOU are doing something wrong .
    6 or 12 volt ?
    Where is the battery located ? Trunk. ? Do you have a dedicated 1/0 ground cable direct from battery to bell housing bolt ?
    Are all connections clean and tight ?
    Do you have the correct ground ?
    Jim, bangin' on old cars since 1957.
    Still attending the "School of Hot Rod Hard Knocks" since 1957
    410 474 2244
  20. 50 Merc Man
    50 Merc Man
    Yessir to all the above!! 12 volt, battery under hood in original spot, and proper ground strap
  21. Many times the engine is not grounded so the starter is fishing for a ground, do ground from engine to frame and engine to firewall and starter to engine. 4 ground wires.
