Technical Power Ram SBC Early Mickey Thompson Cross Ram Versions and Attributes
Discussion in 'The Hokey Ass Message Board' started by BOSTONCAMARO, Feb 27, 2023.
  1. Hello All,
    I have what I believe to be a one year 1963 or 1964? cross ram with 4 holes showing at each carb flange.
    I also have a Power Ram (friend is buying this off me) on the bottom it looks like there is an open slot as cast, I do not think anyone cut this out, any ideas in this? maybe to get warm oil to intake to warm up motor? not that you want warm oil on the bottom of an intake.
    Appreciate any insight you all have.
    Tim 7637BADB-FE78-4653-B2AD-10402678B8A9.png D3046363-035B-4795-BC98-A2373B058DE6.png ABCE42F3-62B0-4F29-936E-E9E5139A676C.png 2228CAE8-CA25-4B58-92C8-9A8389B1B3E4.png
    Deuces likes this.
  2. It should be an exhaust riser. It would have been to warm the intake.
    I may be wrong but that is what it looks like to me.
    BOSTONCAMARO and NoelC like this.
  3. Fordors
    Fordors
    It may have been nothing more than a way to get the core sand out of the casting. It's hard to visualize but I believe they put a core above that area so there wouldn't be a solid chunk of aluminum there.
  4. theHIGHLANDER
    theHIGHLANDER
    Does it bolt down thru the carb bores in the center? I can't say on the big slot. Weird...
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pics, please select "full image" when posting it makes it easier for people to help. also if you would crop the black out the pics would be larger yet...
    bchctybob, carbking and BOSTONCAMARO like this.
  7. Ebbsspeed
    Ebbsspeed
    I don't think it is an exhaust riser. Zoom in and you can see that both sides of the exhaust riser ports were eliminated in the casting. If they were ever there someone did a darned fine job of blocking them. I'd agree with the conjecture that it's a slot for the core sand to drop out of.
