1952-59 Ford power steering conversion
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Mar 24, 2020.
  1. BeerMoney
    BeerMoney
    im thinking about doing the power steering on my 55 customline i seen a post where you could buy the kit for this but now i cant seem to find it.
    can some one point me in the right direction
    Thanks/
    Roothawg likes this.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. mark latham
    mark latham
    Is your car manual or factory PS? Do you want to upgrade to an integral steering box or a rack? What engine do you have? If you want an integral unit Borgeson makes a unit including a pump but it needs either a manual steering drag link or an adaptor to connect the pitman arm to the PS drag link. All in you would be at around $1000.00. If you want a rack Unisteer makes a kit and depending on where you get them your looking at over $2000.00. Look around here on the HAMB as I have seen a lot of posts from people that installed racks and then went back to stock because they didn't like them. The Borgeson unit supposedly has header clearance issues. I have been looking at converting my factory PS but haven't decided what way to go yet although I am leaning toward the Borgeson unit as all the rack pumps look too street rod and I don't think the benefits of the rack are worth a $1000.00 increase in cost. Here are some links to look at.
    https://www.borgeson.com/xcart/home.php?cat=117
    https://www.speedshopstore.com/1955...-pinion-for-small-block-unisteer-8011640.html
    https://www.hotrodhardware.com/inde...d=5081/category_id=1201/mode=prod/prd5081.htm
  4. okiedokie
    okiedokie
    from Ok
    I like my Fatman rack setup just fine. Did lose some turning radius but getting used to that.
  5. jimmy six
    jimmy six
    Split the column under the dash and install electric ***ist. They make them for the early Corvettes.
  6. bobss396
    bobss396
    I may go rack and pinion on mine. I have bad exhaust manifold clearance as it is.
  7. nascardave
    nascardave
    You may consider installing 70s style Ford Granada power steering. If this would be something you would be interested in. I have the instructions, and may have all the core parts. Less the power steering pump which is not a big deal.
  8. BeerMoney
    BeerMoney
    do you have the power steering unit
  9. nascardave
    nascardave
    Yes, I have all the lower power steering core parts. I do not have a power steering pump. Thats easy to come by. I have also sent you a personal message.
  10. cka7
    cka7
    Kustomline54 likes this.
  11. BeerMoney
    BeerMoney
    do you have the instrutions on how to install the power steering
    you said you have all the parts except the pump
  12. nascardave
    nascardave
    Beer money, I have sent you a personal message.
  13. Roothawg
    Roothawg
    Is the Borgeson box the same size as the stock manual box? I am trying not to buy stuff I can't use in the future. I am swapping a 5.0 in with the "P" heads. I bought the Sanderson shorty headers.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    The Borgeson Box is bigger and has always created exhaust clearance issues in 52-56 cars. Makes that electric power steering look even more inviting no pumps,hoses or brackets on the engine to deal with.
  15. Roothawg
    Roothawg
    Anyone have a pic of the Borgeson box installed? I searched for the thread mentioned, but I couldn't find it. If I don't have power steering, I have to design an idler pulley to replace the power steering pump. I can do it, but It might be easier to use the Borgeson box.
  16. jimmy six
    jimmy six
    On the y-blocks forever website and the FOMOCO Time magazine of the Crown Victoria Owners they both have step by step of the Borgeson.... Looks like a PITA to me. But my stock PS works great.
  17. Roothawg
    Roothawg
    I still haven't decided if I am even going to add PS. My manual box works ok, but the wife would appreciate it. It looks like a lot of work, no matter how I attack it.
    bobss396 likes this.
  18. fordsbyjay
    fordsbyjay
    from Lafayette
    Here is a picture of the two side by side. The borgeson box is a lot taller on top. I put a 460 in my car and it is right in the way. I never installed it with the 302 but there has to be tons of room. It bolts right in and may require a bit of shimming. The only hard thing is to attached the steering column to the top. If you are switching to a new column anyways it is really no different.
    mammyjammer likes this.
  19. Roothawg
    Roothawg
    Thanks for the pic. That helps. I am hung up on the column. I like the idea of getting rid of the death spear, but I would like to retain the stock wheel. I contacted Flaming River and they said they don't have an adapter to go from a later styled column to the original wheel. Just the other way. I swear someone on this board has done it. I just can't remember who.
    I figure the column shift will be a no go with the PS and a 5.0.
  20. JeffB2
    JeffB2
    from Phoenix,AZ
    fordsbyjay likes this.
  21. evintho
    evintho
    Roothawg, have you given EPS any thought? It's well under a $200 upgrade and the simplicity of it is mind boggling! No pump, reservoir or hoses to clog up your engine bay, no fluid to leak all over everything and you can use your original steering box. The EPS motor tucks up under the dash and you don't even notice it.
    Granted, I can't give it a real world review 'cause the car isn't roadworthy yet but, from other reports I've read there are no issues with it. I'm just about done with the conversion. Only need to wire up the 'Bruno' controller and mount my Mooneyes steering wheel. When I'm done I'll post a full write-up.
  22. Roothawg
    Roothawg
    JeffB2 and fordsbyjay like this.
  23. Roothawg
    Roothawg
    You should do a tech piece for us. I would love to see your write up.
    I am not 100% sold on any given system. I really want to send my wheel off to have it pearlized, but I don't wanna drop that cash if I can't use it. I'm guessing it will be floor shift? Not sure how much room I will have under the tunnel for the Lokar style shifter.
    I know I sound wishy washy, but I just don't want to make the wrong decision and regret it.
  24. fordsbyjay
    fordsbyjay
    from Lafayette
    Well I can't wait for that writeup. Seems how my PS won't fit I have been looking at the EPAS. There is units where you don't even need a box now. I am curious as to what you did to seal the top of the original steering box now.
  25. This kind of takes me back to the days when we all got excited over the Jeep power steering conversion. there were a couple guys who actually did it and a bunch of us who started the conversion. I even made copies of the brackets and sold them to a few fella's on here. But in the end most of us had nothing but trouble, and gave up. I know I did. I would love to see a write up, and a car that is actually running and driving with the EPAS. it seems like a great conversion. In the meantime, I completely rebuilt my stock box and entire front end. So we'll see how it drives when I finally get it on the road.
  26. Pheaton193
    Pheaton193
    from Reno, NV
    I put an EPAS in my ‘53 a number of years ago and have never looked back. Yes it was a little work but the results are great. I used a Unisteer 360 watt unit. It was expensive but the performance continues to be excellent after three years. With the many cars that use EPAS today, there are also alot of units available that will work and not cost a fortune.
  27. jailbar joe
    jailbar joe
    over here in oz the 67/70 falcons/fairlanes had the power ram that hooked up to the drag link....was a very simple and effective method of power steering also it was very similar to the original set up i have on my 56 victoria.
    don't really have to change much...just add ram,this could attach to the drag link via a suitable clamp....
    i plan on upgrading the ram on mine when it is time for a rebuild.
  28. JeffB2
    JeffB2
    from Phoenix,AZ
    A fair amount of guys on some facebook Ford forums used the Saturn Vue unit watch these two videos: And
  29. Roothawg
    Roothawg
    Good stuff guys. I appreciate the info.
    mikhett likes this.
  30. cka7
    cka7
    I'll have to disagree having done the upgrade myself. I picked up considerably more clearance with the Borgenson unit on my 54. Although the Borgenson is larger it is positioned differently in the car. I could fit the Patriot Headers and Hedmans without any mods with the Borgenson, Not so with the stock gearbox. I wish I would have done it first. Would have saved some banged up tubes.
