Hot Rods Power steering conversion
Discussion in 'The Hokey Ass Message Board' started by oldsvroom, May 27, 2024.
  1. oldsvroom
    oldsvroom
    I’m running a 31 model A with original frame, front axle and spring and a sbc engine . It’s getting harder for me to turn when trying to maneuver into or out of a parking spot . In considering converting to power steering . Have any of you done this and what box did you use ?
    Bandit Billy likes this.
  2. figure8
    figure8
    Speedway and summit have a power box that fits where a Vega box goes. I’m thinking about trying one on my ‘32
  3. oldsvroom
    oldsvroom
    I forgot to mention im running a reverse Corvair steering box
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What’s your rim width and tire size?
  5. oldsvroom
    oldsvroom
  6. jimmy six
    jimmy six
    Get skinner tires, 85 series, 4-1/5” to 5” rims and run them at 35 psi…. You would be surprised the difference. Lastly a 17” steering wheel if you don’t have one now.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
  8. oldsvroom
    oldsvroom
    I’m not going to change wheel size and I’m already running a 15” steering wheel if I run anything larger I won’t fit in the car. Power steering help only please.
    seb fontana likes this.
  9. willys36
    willys36
    Is it legal to talk about power steering on this site? I've been censored for doing it a couple times.
  10. seb fontana
    seb fontana
    from ct
    Personally I don't see why you were censored. I posted about electric power brakes and I don't think it made 30 seconds, maybe I just couldn't find it later. To me if it will aid in the operation of the vehicle why not "allow" it.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    Normal power steering and brakes are ok. Modern electric ****… no way
    dana barlow likes this.
  12. Kerrynzl
    Kerrynzl
    To keep it side steer, hunt down a Toyota Land-Cruiser [or straight axle Hi-Lux 4 x 4] steering box / pitman /pump /lines.
    Here is a non-power steer box to show you the layout
    Here is a P/Steer box
    available off Ali-express
    dana barlow and JohnLewis like this.
  13. I mean....power steering isn't necessarily off topic. This is a pic of the factory power steering setup my 53 bel air had FB_IMG_1716749909554.jpg
  14. BamaMav
    BamaMav
    from Berry, AL
    Don’t poke the bear!!!!!
    Gently point the discussion to the off topic forum, don’t try to start a war on the original board.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    OK, for people that don't seem to know the rules here, there is nothing wrong with hydraulic power steering as it was offered on cars in 1965 and before. The Hamb is a traditional hot rod forum that focuses on 1965 and older build styles on 65 and older cars. There is a new off topic forum where it is perfectly fine to discuss elect power steering and Pinto independent front suspensions and rack and pinion steering....
    Tow Truck Tom, BamaMav and 57 Fargo like this.
  16. 57tailgater
    57tailgater
    from Georgia
    CPP offers power steering kits for late 50's Chevy and Ford pickups that fit original steering side steer set ups. Bolts to the inside of the frame rail. Don't know if it will work on your car but it's an option comparable to the Toyotas previously mentioned. Shop around if interested in this route as multiple vendors handle these.
    https://www.cjponyparts.com/cl***ic...bpa_-mBEjCWIneqDWoCNueN56DNVnx1xoClFQQAvD_BwE
  17. Mr48chev
    If effort is getting increasingly harder with that Corvair box I'd say that the main issue is that the little designed for Well under 1000 lbs on the front tires. Skinny little 13 inch front tires at that. The bearings in that box are probably getting in pretty bad shape.
    Even a non power land cruiser box would be a big improvement or an F-1 box or F100 box that are a lot better Model A conversion box than Corvair that shoudn't be put on anything heavier than a T bucket. Screenshot (289).png
  18. pprather
    pprather
  19. 05snopro440
    05snopro440
    I read that as he was finding it harder to steer because of his own physicality, not because it's actually getting more difficult.
  20. Bandit Billy
    Bandit Billy
    @Moriarity why don't we scoot this thread over to the OT forum for him? I think it is a great question. As we age, we may not be able to drive manual steering cars but still want (and have a rite) to drive hot rods. I have a great many friends who have lost the use of both arms, PS and automatics are the only way they get to play. I'll share what I did to my PU that allows her to drive it effortlessly after the thread is in the proper location.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    power steering is ok here.
  22. Bandit Billy
    Bandit Billy
    Uh, not the way I did it. :cool:
    fauj likes this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    I know....
    Johnny Gee likes this.
  24. ROADSTER1927
    ROADSTER1927
    HUNT2122.JPG HUNT2111.JPG HUNT1148.JPG My 40 Pontiac has a 1978 Elcamino front stub with power steering and power disc brakes on the front. Gary
    dogwalkin likes this.
  25. Are hydraulic PS ***ist units that go between the column and box an option
  26. gene-koning
    gene-koning
    Why don't you start a thread over on the off topic section covering "Adding power steering where it wasn't."?
    Then if someone has options for adding PS on traditional cars they can post here, and if someone might be looking for a modern way to add power steering to a vehicle that didn't have it before, they can look into the way you did it there.
    pprather, Moriarity and Bandit Billy like this.
  27. Bandit Billy
    Bandit Billy
    I'll do that. Good idea.
    pprather likes this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    I wouldn’t mind seeing a picture of the OP’s car. It could be a scrub radius isue if he has reversed wheels and wide tires on the front. Might not even need power steering….
    JohnLewis and Johnny Gee like this.
  29. pprather
    pprather
    Or a new reversed Corvair box.
    Moriarity likes this.
  30. oldsvroom
    oldsvroom
    Thank you this information is what I was looking for .
    JohnLewis likes this.
