Hot Rods Power steering conversion
Discussion in 'The Hokey Ass Message Board' started by oldsvroom, May 27, 2024.
  1. twenty8
    twenty8
    Little bit too much scrub radius, little bit too much tire width, little bit too much caster, little bit too much steering ratio, getting older....... It all works against us.
  2. Kerrynzl
    Kerrynzl
    Some people get out of their depth with steering geometry . This ^^^ is where a seemingly small tolerance can turn into a major problem.
    So my argument for the dreaded EPS is somebody who is out of their depth can install it and not f*** with the geometry.
    We are all "aging-out" and our bodies are paying the price for past sins. So power steering of any type is a step towards keeping these old dinosaurs [the cars :D] on the road.
    As Moriarity said, there is an off topic section here that can tolerate this off topic subject [with getting burnt at the stake]
    @oldsvroom If you cannot find a Toyota "side steer" power steering box , then leave all your steering components and geometry alone.
    Then Add a power steering ram ...........But not the "unpredictable" OEM style like on early cars.
    The problem is the vagueness caused by the control valve being in the ram itself [this has a direct effect on steering angles]
    USE a sprint car control valve in the column [eg: Sweet] and plumb this to the ram. Having the control valve in the column reduces vagueness due to the steering box ratio.
    All OEM power steering boxes and racks have the control valve on the column/pinion side .
    Bandit Billy and anthony myrick like this.
  3. oldsvroom
    oldsvroom
    Great where do I find this?
  4. Kerrynzl
    Kerrynzl
    Anybody that plays with dirt sprint cars.
    There are plenty of people throwing their toys out of the cot in racing circles
    Here is a new one
    https://www.kartek.com/parts/sweet-...ion-34-30-spline-to-driver-34-48-to-rack.html
    If you knew what you're doing, you could chop up a power steering rack [cut off the pinion and add a column]
    Power racks have the same 4 hydraulic ports as the Sweet unit
    But this ^^^ could be just as costly.
    And by the time you get all the components together the Toyota side steer power steering box might be more attractive
  5. seb fontana
    seb fontana
    from ct
    Jegs, Sumitt, Speedway, Sweet Mfg. or google race car steering parts?
  6. willys36
    willys36
    We are not supposed to discuss R&P steering.
  7. dana barlow
    dana barlow
    from Miami Fla.
    Liking a soft ride,often some run tire PSI a bit low=Dose help ride,but it has the side affect of steering very hard when stopped,same as using tires on front that are over 5 inch's wide. Same goes for high caster number,of over 5*= Any or all of those things,can be adjusted out,an car will then steer with a lot less armstrong use.
    Are you in any of the boat above??? If so,try some adjusting,and see if,after you may not need power steering after all.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Honestly, why not do a ford f1 or f6 steering box with a shortened pitman arm? Its actually easier on a model a than power steering all around and less junk to screw with.
    pprather likes this.
  9. Mr48chev
    If this is the car in question, the too fat under inflated tires with too much negative offset on the wheels (look cool though) wheels are a bit part of the problem. There is probably a couple hundred pounds of unnecessary decorative weight hanging on the front end that could be tossed in the s**** pile too.
    I'd bet dollars to donuts that that car didn't have those wheels or all that "theme" frufru nonsense a few years ago when it drove pretty decent.
    dana barlow and Moriarity like this.
  10. That hurts my eyes....
  11. 57 Fargo
    57 Fargo
    Hey whether the car is ones taste or not, at least he’s out enjoying the car!
  12. oldsvroom
    oldsvroom
    Then don’t look !
  13. oldsvroom
    oldsvroom
    Thank you . This car gets a lot of positive attention and we go all over in it .
  14. oldsvroom
    oldsvroom
    Thank you I will look into all of the above when I have a few spare minutes, right now I’m working out of town so that is hard.
    dana barlow likes this.
  15. Kerrynzl
    Kerrynzl
    That car is in better taste ,than the flamed paint job on the "late model" in the background.
