Technical Power steering for a 55 fairlane
Discussion in 'Traditional Hot Rods' started by michael dunphy, Apr 8, 2020.
  1. michael dunphy
    michael dunphy
    I have a 55 fairlane that I put the power train from a 79 thunderbird in it! I have the all the parts from the thurnderbird and I was wondering if I could use the power steering box and pump on the 55
  2. Jalopy Joker
    Jalopy Joker
    since not a common set up - do a lot of measuring, checking geometry for turning, pressure required, etc
  3. okiedokie
    okiedokie
    from Ok
    Join the 52-59 Ford social forum. All the info you need there. I used a Fatman rack in my 55 but Borgenson has a nice box that fits.
  4. southcross2631
    southcross2631
    Fatman makes a rack for just about any old car .They even had one for my Morris Minor after I put a Mustang 11 front end under it.
  5. bobss396
    bobss396
    The Borgeson boxes are bulkier that the stock boxes, so you may have less exhaust manifold clearance than before. This is the issue with my car. I'm leaning towards R&P in my '59.
  6. southcross2631
    southcross2631
    I did a rack conversion on a 57 Chevy before kits were available. We used a Buick LeSabre rack and a Camaro pump. We had to build a few brackets to install the rack on the frame and we had to ream out the spindles to fit the tie rods. We changed the column out and used a double D shaft.
    We had a hose shop make up the pressure hose.
    If there is not a kit available you should be able to use a T-Bird rack.
