Technical Power steering need help
Discussion in 'The Hokey Ass Message Board' started by rodscout, Nov 23, 2023.
  1. rodscout
    rodscout
    from germany
    Hi Guys i need some help .
    Did some body know the Brand and Typ of this steering box see pictures attached.. i need a seeling and a bearing for input shaft.. has a little play and leaks...
    Thank you so much in advance.
    Uwe
  2. nobby
    nobby
    It maynot help much but
    that to ne is a ford power steering box
    might be a mazda pickup part too.box
    or a ford van
    is it being over pressurised, is there any form of cooling in the return line
    p.s. just because
    -i just so happen to have two identical engines, one from a fwd car and one from a rwd car - idicating different steering racks.
    they both use identical power steering pumps.
    the pulleys interchange, one is a few mm or an 1/8 larger
    when you do the '2 pi x r ' it soon becomes appaernt that its a greater distance travelled.
    do you happen to have solid lines going straight to the input?
    as i am in the beleif that the internal springage of the rubber hose actuall spins the pressurised fluid and takes the pump pulsing out - maybe.
    or
    at what pressure do they see? is it mega psi?
  3. gimpyshotrods
    gimpyshotrods
    If you just need a bearing and a seal, you might be better off taking both out and looking for part numbers on them.
    If there are none, careful measuring of the dimensions will allow you to purchase replacement ones from a supplier.
    Parts are often designed to fit common bearings and seals, for ease-of-service.
  4. inthweedz
    inthweedz
    I did my friends input seal on his 64 Dodge (sedan) he was going to spend $$ on an overhaul kit, apart from the leak, there was nothing wrong with his box.
    We measured the seal, inside dia/outside dia, then bought and fitted an aftermarket seal, fixed the leak for a couple of $$.. To me, that seal on your input shaft looks like an ordinary oil seal, held in with a circlip..
    As for bearing play, do you mean free play/in the steering wheel?? If so, that can be adjusted with the adjuster on the sector shaft housing, just set the box to dead center, back off the lock nut, and slowly screw in the adj screw (while giving the input shaft small back and forth movement) adjusting the play out till there is no slack between the input shaft, and output shaft, then lock up the lock nut..
    P.S. To remove the seal, first remove the circlip, get a sharp spike and punch a SMALL hole thru the outer shell of the seal (keep the hole close to the housing, you don't want to scar the shaft), screw in a self tapping screw and pull out the seal with pliers, might take a couple of attempts, depending how tight the seal is, and size of the screw..
    vtx1800 likes this.
  5. rodscout
    rodscout
    from germany
    Thanks a lot guys for the comments.
    @inthweedz..play is not in the steering ..it's the input shaft, little to the sides.
    So Brand and typ will be still helpfull.
  6. brading
    brading
    If there are no numbers on the bearing and seal take them to your local bearing dealer and they should be able to match them up.
    hook00pad and X38 like this.
  7. inthweedz
    inthweedz
    Ok, a quick question rodscout..
    If you take off the end housing (four allen screws) is it a plain bush, or a tapered bearing? if it's a tapered bearing, are there any shims between the housings, or any behind the bearing?
    If so, that could be where you can adjust the bearing ''play''.
    If it's a bush, it'll need replacing.
  8. seb fontana
    seb fontana
    from ct
    Looks like a Isuzu Trooper [2001] box. Borgenson uses these boxes for alot of conversions.
    Tag on the box I have:
    897109986
    441-00510
    JKC 1118
  9. dirt t
    dirt t
  10. rodscout
    rodscout
    from germany
    Thanks a lot guys, we try to fix the sealing but it did not work , and a ISUZU looks different.. so i still have to find out Brand and Model of this steering (pictures abowe) so i will buy a new one. The Lares 11206 is matching to the shafts but its a little bigger but there is no space for it between frame and engine.
  11. X38
    X38
    I can't help myself...what car? Why power steering?
  12. inthweedz
    inthweedz
    Hey rodscout, I would strip the old box down first before buying a new one, it might be an easy fix, if not, now you have a good reason to spend the $$$ on a new unit..
  13. nobby
    nobby
    do they call them the 500 series pas boxes
    i was thinking a 1998
    ford E series van
    just because of the short sector shaft
    its if you like similar to a saginaw 800 series
    ooh i wonder if they do a right hand drive version
    and its a smidge smaller than a saginaw 800
    or if the mounting foot is easier to deal with
    hmm
    anyway, i think you are all missing a trick in that if you have a 35-40 ford
    you could have a solid shaft from the box to the wheel like the 65 mustang or 66 chevy2
    into a 525 or a power box, its just a slot on a shaft with a tapered spline at the wheel end
    so much easier that having uj's
    fancy turn signal switch with hooters on the turn switch
    done
    thanks
  14. rodscout
    rodscout
    from germany
    It's a lefthand drive ..it's installed in a 1947 coupe deluxe
