Hot Rods power steering pump
Discussion in 'The Hokey Ass Message Board' started by Dick Lobach, Aug 27, 2015.
  1. Dick Lobach
    Dick Lobach
    from Emmaus Pa
    I am using a power steering pump from a 72 mopar with a K-car power rack. This is the third rack that I blew the seals on. Can the pump pressure be changed on the mopar pump like they do with GM pumps with Mustang racks ? Or at least I thing that's my problem.
    Thanks
  2. mgtstumpy
    mgtstumpy
  3. Most steering pumps have a relief valve or hydrostat in them,they are adjustable but you would have to put a gauge in the line between the pump outlet and the rack,otherwise you wouldn't know where you are pressure wise. If you haven't got the gear or know what you are up to ,better off going to a power steering joint and get them to adjust it for you.But yes,they are adjustable.
  4. Last edited: Aug 28, 2015
  5. Hnstray
    Hnstray
    from Quincy, IL
    How about using a K car pump? Should be correct pressure for the rack......
    Ray
