1952-59 Ford power steering question
Discussion in 'Off Topic Hot Rods & Customs' started by Oldskoolbelair, May 28, 2011.
  1. Oldskoolbelair
    Oldskoolbelair
    okay guys this may be a dumb question but here it goes. My victoria is a power steering car, An at some point in time the hydraulic ram got damaged. Can I just remove all the old hydraulic hoses an ram an just run the box manual. It still feels like it is in good shape.
  2. fordsbyjay
    fordsbyjay
    from Lafayette
    I wouldn't see why not. It is a power ***ists so it is not real power steering (at least in my mind). Without it you have manual steering.
  3. Custom_Crestline
    Custom_Crestline
    What you might do, because those are rare bits after all, take all of the PS stuff and sell as builders/cores. Heck, those eaton pumps are even getting hard to find
  4. Oldskoolbelair
    Oldskoolbelair
    Thats what I figured buy wasent sure. I always read about guys putting after market power steering on their car but never just pulling it off an useing the box for manual. I am going to save all the stuff off of it an sell it.
  5. Custom_Crestline
    Custom_Crestline
    I'm not sure, but you may need a new tie rod, and at least idler arm to actually convert it to a manual steering car, as the PS cars obviously had different tie rods and not so obviously different idler arms. I do believe that the ratio on the boxes is the same, with that being said I have never driven a manual steering '54, but I know my turning ratio is pretty sad, to say the least!
  6. 54HotRod
    54HotRod
    Mine is only manual steering and it turns pretty well for a non ***isted turning car. I feel that I can turn pretty well with the car and I only want power steering when I am sitting still or when I'm just being lazy. However right now I just want my steering repaired no matter what.
  7. Oldskoolbelair
    Oldskoolbelair
    I found on ebay the whole steering set up except for the box of course its all nos stuff so I was going to order that an replace everything. The manual steering dosent bother me at all I had a 53 belair that was all manual too an I drove it everywhere
  8. riskybiz
    riskybiz
    Oldshoolbelair, Concourse carries alot of the parts to rebuild or exchange what you need if you want to keep it original. When I rebuilt my steering this is were I went. A yr ago after doing a jeep change over on my 55 I did the same to my two 54's. Steering is much faster now lock to lock.
