1952-59 Ford Power steering upgrade
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Sep 18, 2011.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
    Borgeson now has a Y-block pump and bracket available to go with the power steering box.
  2. vein
    vein
    The link didn't work jeff, can't click into it.
  3. the-stig
    the-stig
  4. hebman
    hebman
    from houston
    will it work with 3 on the tree
  5. flyboy89
    flyboy89
    from So. Cal.
    Hebman, with that Borgeson box you need to shorten the factory steering shaft, but I don't know how much. It might be a problem with column shift.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    I think webrodder also has a link to the install,to get the straight scoop I would call Borgeson's Tech line.
