Projects Power train swap--250 in a 50 chevy
Discussion in 'The Hokey Ass Message Board' started by roosters hot rods, Dec 3, 2008.
  1. roosters hot rods
    roosters hot rods
    this all started about 6 month's ago when a friend of mine want to repower his 50 chevy,it was all origanal...so i told him hey lets put a 250 inline in there instead of a small block..gas was 4 bucks a gal :eek:so what the hell.we hunted up a 70 nova and removed the engine and trans,a turbo 350,and the rear.the engine got a bone stock overhaul,and i installed a langdon's stovebolt split exhaust manifold:cool:.the trans was also overhauled.i insalled the rear,it fit like it was made for the car,i had to fab up some u bolt saddles but other than that its perfect.
    i had to cut the the center of the frame..so i could fab up a tube trans x member..i made out of 1.5 tubeing..1.25 wall... then it was on to the motor mts and i wanted to use the sock rubber mts..so i fab up some cool loooking plates and welded them in...the drivers side was a little tricky but clears all of the steering gear.i hope to have this project finished next week..i really want to hear it with the duel smithys..:D
  2. roosters hot rods
    roosters hot rods
    more pics
  3. roosters hot rods
    roosters hot rods
    and some more
  4. roosters hot rods
    roosters hot rods
    and a couple more
  5. 56sedandelivery
    56sedandelivery
    I have a 51' Chevrolet Business Coupe. This is what I was planning on also, but I'm keeping the stock 3 speed/enclosed driveline by using an old Speed Gems adapter I have. So, when can you come up and do the "hard" work for me? Switch your old point distributor for and HEI unit; if you grab hold of and move the points breaker plate around you'll see why. Good job! Butch/56sedandelivery.
  6. 29nash
    29nash
    from colorado
    Fits like a glove. Nice work on the pipes.
  7. roosters hot rods
    roosters hot rods
    the pipes:D
  8. roosters hot rods
    roosters hot rods
    drag it to florida....i'm ready for the next one..:)
  9. 29nash
    29nash
    from colorado
    Just in case you don't know, to save you some money to spend on what you really need, until you really, if ever, want to run it flat-out, the points distributor will be more than adequate, all the way up to IH left lane speeds and beyond.
  10. Joe Daddy
    Joe Daddy
    Good choice for engine swap...
  11. roosters hot rods
    roosters hot rods
    got most of the wiring done today...now have to change all the bulbs to 12v...more updates coming...dave
  12. AHotRod
    AHotRod
    Your doing a excellant job on the Chevy Dave, it's gonna be very cool.
  13. hotrod mike
    hotrod mike
    You're doing a great job there brother. Your buddy is gonna' have a bitchin' hot rod when you get through with it. Thanks for the update. Mike
  14. Hey, That looks kinda familiar, right Cfish?
    One Eye did a truck 250 and put it in Chad's Chevy... had to fab up with all kinds of brackets to make it work.
  15. roosters hot rods
    roosters hot rods
    thanks guys..
    i like the new avatar BM
  16. Yours too, the guy who did them is, no doubt, popular with ladies... :)
  17. I'm figuring to do this with mine (also a '50), but go still another route - keep a manual trans, but use the T4 (that was supposed to be a T5) I got for it originally.
    I figure if a 250 works in my buddy's old plow truck to push snow around, it aught to move one of these little Chevys pretty good too.
    Any issues with radiator clearance to the fan with this swap?
  18. hotrod mike
    hotrod mike
    Hey, who's that guy? Can ya hook me up with him? I want a new avatar too.:p Mike
  19. 021k26rr
    021k26rr
    from TN
    Where did you get the exhaust manifold from I am about to do the same thing and I would like to get one.Does it make a big power difference.
    Ben
  20. 021k26rr
    021k26rr
    from TN
    is there a big diffeence between a truck 6 and a car 6.
  21. nexxussian
    nexxussian
    Looks real sharp, with one exception.
    It needs a high carb diet.:D
    With the Langdon split manifolds it would really look good with 2 carbs (3 would be titserific, but excessive for the goal stated).
    Even the Offy 4V intake would be good with a small carb on it.
    Or Webbers.:D
    Not knockin it.
    I know all those aren't particularly cheap, but thought I should 'suggest' it.
    Definetly looks as if you have it well in hand.
  22. roosters hot rods
    roosters hot rods
    i had to move the radiator forward...about 2 inches,still lots of room in there,......dave
  23. roosters hot rods
    roosters hot rods
    go to langdon's stovebolt.com...he has some killer stuff...dave
  24. roosters hot rods
    roosters hot rods
    anybody else doing a fuel sipper engine swap???
  25. nexxussian
    nexxussian
    With the regear in the Anglia we got just under 37MPG (highway only, already warmed up, diving for max milage, just to see).
    But the engine is completly OT for this board (too new, and electronic to boot).
  26. Bash'n'Weld
    Bash'n'Weld
    I'm also planning on doing the 12v conversion as well, what else besides the wiring and lights have to be changed?
  27. AHotRod
    AHotRod
    Are ya done with the car yet ???????
  28. roosters hot rods
    roosters hot rods
    very close brother...waiting on a few new parts...next week it will drive.
  29. Voltage drop or swap out on the fuel and temp gauges.. and I'd rewire the ammeter to be a voltmeter, or swap that out too. Horn relay. (the horns will work on 12V, just don't hold them down forever and ever). A later GM headlight switch would be a nice change, not required, but I think you can use the stock bezel and knob on one as late as the 80s.
  30. randy rhoades who built the grapevine clone outta the 52 chev it has a 68 nova motor and suspension, 250 straight 6 (not for long a 290 souped up motor for BONNEVILLE!!!)
