Power Valve
Discussion in 'The Hokey Ass Message Board' started by oregonite, Apr 8, 2012.
  1. oregonite
    oregonite
    I'm currently running a 670 Holley Street Avenger on a 327 with a .480 lift cam and getting 10 inches vacuum. It has a 6.5 power valve in it. Would it be better to put a 4.5 power valve in it?
  2. need louvers ?
    need louvers ?
    You are really the only one that can answer that. A power valve OPENS when vacuum falls BELOW it's set point, say 6.5, and enrichens the whole deal. Put a vacuum guage on you car and drive around a bit and see where your vacuum numbers go. It's best set up so your power valve is closed at steady state cruise but opens at acceleration.
