Technical Power windows in A
Discussion in 'The Hokey Ass Message Board' started by flatblack37, Feb 16, 2015.
  1. flatblack37
    flatblack37
    from LA
    I have a 31 Model A Tudor. Would like to add power windows to the front only. Any recommendations of which brand or full kit best fits?
    Thanks
  2. dana barlow
    dana barlow
    from Miami Fla.
    All though its not a thing I would do,I don't see why you could not just find a set up out of a junk car that could be used with some small mods for near nothing vs a kit of some type. Well just a idea!
  3. flatblack37
    flatblack37
    from LA
    Thanks. With the flat gl***, a kit would be easier and already have wire and the switches. Just curious what other Model A guys have done, if at all.
  4. gnichols
    gnichols
    from Tampa, FL
    Depending on your budget, I recommend this firm highly. They use the OEM regulators, too. Gary
    https://nu-relics.com/
    AHotRod likes this.
  5. Boolajosh
    Boolajosh
    from Monrovia
    I can't remember who makes it, but there is a kit where you can use your stock model a handle, and it controls the window switch. That way it looks stock, but is full power window
  6. HOTRODPRIMER
    HOTRODPRIMER
    Back in the earl 70's I bought a Model A pickup that was missing the window regulators so I used the power window regulators from the Chevy Caprice I pulled the engine and transmission from.
    It's not traditional but worked slick as a whistle.
    Pretty easy modification. HRP
  7. scrap metal 48
    scrap metal 48
    Power windows in an A.. Really???
    117harv likes this.
  8. 911 steve
    911 steve
    from nebraska
    Auto-loc makes a switch kit that does that. I have in my 40 Ford. but you still need regulator/motor, I think I got mine thru Vintage Gl***. I had a body shop do mine. only bad thing with the switches was they seemed sticky & didn't want to spring return. so I took the cover off & lubed it with anti-seize lube. my handles had to mount vertically to prevent the weight of them holding the switch open.
  9. BOBCRMAN
    BOBCRMAN
    from Holly
    I used the motor and mechanism from a 90's Honda Civic. Very compact. Used a double pole switch on the door handle.
  10. pitman
    pitman
    I used early '60's Lincoln motors/switches. Mt. forward at base of door, w/a vert. link up to window
    riser arm. Quite simple actually.
  11. AHotRod
    AHotRod
    X100 on Nu Relics Power Windows
