Technical power windows
Discussion in 'The Hokey Ass Message Board' started by mg67nova, Jul 9, 2016.
  1. mg67nova
    mg67nova
    I am working on a 1964 Impala SS with power windows. I tested the old motors off the regulators and they worked fine in both directions, but slow. Back on the regulators they only work one way. They would start the other way but quit. So I bought new motors and have the same problem. On one regulator I loosened the motor and it worked fine. So why is it binding up? No slop or stiffness in regulators, they move freely.
  2. 57countrysedan
    57countrysedan
    from NY
    Maybe bent just enough? Maybe some lubrication could help? Had a Toyota where the motor was bad and the regulator felt fine but needed a little lubrication.
  3. saltflats
    saltflats
    from Missouri
    When you say the regulator works fine is that with the window hooked to it and in its tracks?
  4. mg67nova
    mg67nova
    No, that's on the bench working it by hand, it works freely. Same with motor attached, on the bench. Works one way, but not the other.
  5. mg67nova
    mg67nova
    Thanks
