Powered By Ford Thread
Discussion in 'The Hokey Ass Message Board' started by FordMaverickFanatic, Mar 5, 2010.
  1. Jerry27Tub
    Jerry27Tub
    Here's my 302 powered tub.
  2. metalshapes
    metalshapes
    Some of mine. ( past & present )
    Y-Block
    Y-Block
    289
    351W
    351W Turbo
    1600 Kent
    1600 Kent
  3. 29 bones
    29 bones
    from so cal
    Hey Bob
    its gone landed in switzerland last week....but its still mine.!!!!!
    Her is a pic of the new owner unloading in the snow...ha..ha...ha
    and the Phaeton that will be on the p.c.h run up to primer nats this year is chevy powered?????
  4. Is that the VCT version? The exhaust sprocket looks that way! Man have a done a load of those timing belts in focus and conturds! Looks awesome and I bet it hauls ***.
    Brad
  5. 29 bones
    29 bones
    from so cal
    here is a nice engine shot.....
  6. Another ford in a ford.
  7. FordMaverickFanatic
    FordMaverickFanatic
    from Taylor, MI
    Might aswell post my car too, I know it's a bit modern but you guys may like the valve covers...
    That's just a mocked-up block though, it's getting a 347 with 185cc heads, a roller cam and a single 4 barrel setup, only because Boss 302 is a little out of the price range. Gonna paint the block and heads dark Ford engine blue (as seen in the pic) to keep it looking period correct.
    BTW, nice cars guys keep them comming...Ford in a Ford is the only way to go (I like to see Fords in other cars too though)
  8. rallisracing
    rallisracing
    our 27......331 cubic inches of Ford.
      212.9 KB
      214.8 KB
  9. 58custom
    58custom
    The Cleveland is not a "big block".
    Cylinder centers same as 351W, 302, 289, 260 & 221.
    Deck height is shorter than the 351W.
    Length of block is same as 302, excepting cast-in timing cover.
    Same bell housing and engine mount bolt patterns as 302.
    Same head bolt pattern as 302, 289, 260, 221 and 351W.
    Weight of basic engine sub***embly is very similar to 351W (457 vs. 448)
    http://58custom.wave.prohosting.com/
    The only part shared with any of the larger Ford engine families is the dizz (same as 460) but a dizz does not a "big block" make.
    The 351 Cleveland is a small, compact engine design. It was the chronically incurious and pooly informed magazines pushing Chevy products and downplaying the HP potential of the Cleveland that started the "big block" Cleveland myth. Of course it beat your 350, it's a "big block". Unfair! (poutrage)
    Ford engines are divided up into named families, not into the Chevy-centric dichotomy of "big block, small block".
  10. hombres ruin
    hombres ruin
    Like the idea of this thread.Heres mine.50 shoebox,50 8ba flathead,aluminum heads &,intake,holley 94s.C4 trans,8'' rear,bagged all round.
  11. 416Ford
    416Ford
    302 with C4 and 9 inch. Now I just need to get to the point where I can put it back in.:(
  12. Bad Bob
    Bad Bob
    from O.C. Baby
    FORD Motor Police!!!!! hahaha!!!!
  13. MP&C
    MP&C
    63 427 LR in a 61 Unibody
  14. kidzintha34fodor
    kidzintha34fodor
    Ford engines belong in Fords, Hemis in Dodge/Chrysler/Plymouth and chevys are good for bowties or boat ancors!! LOL!!! there is nothing wrong with a SBC as long as you keep in a chev or some other off brand! All my Fords run Ford mills!
  15. JimBoB77
    JimBoB77
    NICE setup. I am going to put a 400 in my 53 F100 Street Rod truck. I built a single 4 bbl tunnel ram intake for my late model stock car back in 1980-81, and will be using that along with the special heads I built up for it. I have detuned the engine with a new truck block, deep dish pistons and a milder cam than what I ran in the stock car. I also am only using a Holley 750 Double pumper instead of the 800 Double pumper I used back then.
  16. JimBoB77
    JimBoB77
    ONLY way to fly. I ALMOST built a 32 Chev sedan a few years ago with a Ford 351, but changed my mind as it would STILL be a Chuvorlevit in my mind. and would have taken at least two years to build. So back to working on Fords.
  17. mikemo
    mikemo
    Here's one of my Ford engines...
      551.9 KB
      556.9 KB
  18. JimBoB77
    JimBoB77
    THIS is the first time I have heard of a 351 Cleveland called a BIG block. I have heard of the 400 "Cleveland" called a medium block, but THAT is not a big block either. They are all part of the 335 engine family. The 400 and 351 share the same distributors, timing chains, heads, etc..
    The 400 shares it rear bolt pattern for the ****** bellhousing with the BIG block 460, but that is about it.
    I have found the 400 has gobs more torque than the 351 Cleveland in properly built trim. THAT is what I am building again. Only weighs slightly more than the 351 Cleveland. Less than 30 pounds more.
  19. Drive Em
    Drive Em
    5.0 with a T-5:
    289 powered:
    351 Cleveland powered:
  20. chopnweld
    chopnweld
    from Nor Cal
    Rebuilt 351 Windsor in my 51 Merc.
    Bad Bob: good to see what was under the flamed hood of your merc!
  21. devilleish
    devilleish
    My brother has a flathead / 4-speed in his '51 F-1, soon to run a 302 / AOD, my girl's '59 Country Sedan runs the original 332 / Cruise-O-Matic, and my little sister has a 352 / C6 in her '66 Galaxie 500. Got a small block Chevy myself, but it's the original 265 in that '55 pickup over to the left.
  22. legend
    legend
    from Irwin PA
    Here's mine. 351 cleveland FMX trans and 8" rear in a 41 ford Sedan :D
  23. LOWDUG37
    LOWDUG37
    292 in my '59
  24. model.A.keith
    model.A.keith
    All Fords Here........
    Ford 3ltr V6 EFI with 5 speed
    Ford pinto with 4 speed
  25. junkyardjeff
    junkyardjeff
    I got a 351-W/C-4 in my 55 sunliner but getting all the pieces to go to a 292 Y block and FMX.
  26. 40FORDPU
    40FORDPU
    [/ATTACH]
    Will be re-united before long.
  27. bikeguydave
    bikeguydave
    from Kentucky
    Man thats purdy!
  28. rustyford40
    rustyford40
    from Mass Bay
    i,m using the stock headers that came with my 5LHO. they fit my 40 frame.
  29. Tacson
    Tacson
    Im not a big block kinda guy but I like this one.
