Powerglide band adjustment Question
Discussion in 'The Hokey Ass Message Board' started by Curly, Dec 22, 2003.
  1. What is the correct setting for band adjustment on a '63?
    If I wanted to change the tailshaft from a the '63 tranny to a '65 power glide what all would be invoved?...Simple housing and shaft change or a complete teardown?
    Bye the way new filter/oil change already done and new modulator valve too but did not fix the problem.
    My neighbor just stopped over and asked if I had a torque wrench so he can adjust his bands on his '63 Impala with a powerslide. He was holding a Chilton's book for a '69 Camaro in his hand. It said to torque the band down to 70 inch/pounds. When we did my dad's '64 Imp I didn't think that this was the numbers we used so I called my old man and he says that his Motors manual says 62-63 are different.
    The reason for the tailshaft question is he thinks his 63 tranny is shot 'cuz it slips in high gear when cold, once warmed up it is fine. He has a P/G from a '65 Big Block Impala left over from his last car and the '65 has a longer tailshaft than the '63. He is thinking about putting the '65 glide in and cutting about 1 1/2" from his driveshaft. Seems like alot of work for nothing.
    Thanks,
    Curly
  2. Crosley
    Crosley
    from Aridzona
    70- 80 inch pounds is fine on the band tightening with an aluminum glide. open it up 3 full turns after that.
    tail housing must match the output shaft length. to change the shaft the tranny must be completely disassembled. The planetary unit with shaft is the last item out, first in to the case as the tranny is assembled.
  3. Thanks Crosley. I was hoping you would be the one to see this and reply. Motor Manual said 40 in/lbs and back off exactly 4 turns and Chilton said 70 and back off 3...Guess Chilton won this one.
