Powerglide from Vega, same inside??
Discussion in 'The Hokey Ass Message Board' started by TheTumbleweeds, Jul 30, 2013.
  1. Larry T
    Larry T
    Oxy*****.
    I've always found that if I use cheap parts in a high performance application, I end up replacing them later --------- along with the high dollar stuff they take out with them when they go.
  2. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Theres a point...
    But it will be rebuild and high performance parts inside..
    My main question was if the vega pg has the same parts inside like a regular pg. The differents i have heard is the gear ratio and no oil cool lines.
    I want to build a high performance ****** of this, if its possible
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    My old T roadster had a very hot 283 punched to 292 and a solid lifter cam with single 4bbl. The trans was an air-cooled PowerGlide which the builder of the car told me was done with all late model V8 internals. It survived several mis-shifts into reverse at speed and is waiitng for a new engine.
  4. falcongeorge
    falcongeorge
    from BC
    You wanna use this in a race application? Seriously?
  5. 56sedandelivery
    56sedandelivery
    Bottom line; use an "Ultrabell" type of bellhousing, update to a steel hub, and increase the direct clutch count; for your application, the 1.82 first gear planetary will be fine, even if used with a trans-brake. If you're not using a trans-brake, then use a shift kit; a Trans-Go kit comes with a "spacer" to make the valve body a full manual shift. Use whatever torque converter gets your engine into it's power band. Butch/56sedandelivery.
  6. how much hp from the motor
  7. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    I want to..
    Someone said it was manual shift on these(?) But yeah, I need to do these updates you wrote. Maybe not the transbrake.
    Hum...realy dont know.. Motor spec;
    010 Std Bore
    Trw 11:1 Pistons
    big mouse heads (2.02 intake)
    Edelbrock tunnelram TR2
    2x600 holley
    magneto
    Camshaft 4000-7500rpm
  8. ClayMart
    ClayMart
    Does your trans have a vacuum modulator? If it does it should be a true PowerGlide and upshift automatically. If there's no modulator then it's probably a TorqueDrive and will be manually upshifted, in which case the vacuum modulator wasn't needed.
