powerglide id trouble
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Jan 29, 2010.
  1. olds vroom
    olds vroom
    hello, i have a pg from a swapmeet but dont know what it came from. my pg has a 16 spline shaft and a 9 inch tailpiece with the shifter attatched. im trying to find what it came from so i can locate a slip yoke then build my drive shaft.any help would be great.:cool:
  2. squirrel
    they all had co**** 16 spline input shafts. Is the output shaft co**** or fine spline?
  3. olds vroom
    olds vroom
    the output shaft is 16 spline co****
  4. squirrel
    then you need a co**** spline yoke, they were used on most Chevy transmissions from 55 to about 1964.
  5. is it a chevy powerglide?
    is it all aluminum or cast iron?
    if it's all aluminum and chevy is it air cooled? (air cooled has large holes in the bell area and the torque converter has a metal wind deflector)
    if it's all aluminum air cooled and floor shift w/course spline output it's probably from a 62 nova with factory floor shift
    the 62 trans had a rear pump and course spline output shaft- anything 63 or newer had a front pump and a fine spline (like a th350 output shaft)
    pictures would help
  6. olds vroom
    olds vroom
    my pg is all aluminum and is not air cooled(solid bellhousing) thank you
