Powerglide Length??
Discussion in 'The Hokey Ass Message Board' started by TheTumbleweeds, Mar 12, 2012.
  1. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Hi!
    Shortest POwerglide is....?
    Found one "short", 27 9/16", short enough for a late 50´s FED?
    Thanks Guys!!
  2. squirrel
    should be one a couple inches shorter, from the early 60s. Aluminum powerglides were first used in 1962.
  3. gasserjohn
    gasserjohn
    there are kits to eliminate the tail shaft alltogether .....
  4. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Where can I find such kit?
    thanks!!
  5. BigDrag
    BigDrag
    from Milwaukee
    Just happen to have a shorty glide sitting next to me. It's out of a vintage FED
    Measures 17.5 inches or 44-45mm.
    If you lived closer I could make you a sweet deal on it.
    Best of luck!
    B.Drag
  6. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Do you have a pic on it? Maybe worth buy it anyway =)
  7. BigDrag
    BigDrag
    from Milwaukee
    Here are picts. of the old glide. It has trans brake and 9" converter. It came in the dragster I bought so I don't know the exact details other than it did work but required a explosion blanket.
    I spent $4,000 on the replacement Reid cased glide, a SFI approved case, billet internals, custom converter.....ect. The old trans has been sitting around since then.
  8. oldblue53
    oldblue53
    I'm setting mine up this way also. Short planetary drive an TCI bushing tailshaft support.
  9. BigDrag
    BigDrag
    from Milwaukee
    It's a good set up.
    I went a little overboard on the new trans it's rated for 1500hp. my engine makes less than 700hp. My drag racing buddies like to spend my money on stuff I really don't need but it's good insurance and one less thing to worry about.
  10. Coolchange
    Coolchange
    from so cal
    tsr-racing .com will shorten your stock shaft for about $100. ***uming you dont need a hi HP application as a racing shaft and drum are pricey. Then just get the rear plate and seal. There is a a bushing and a bearing rear plate if I remember correctly.
  11. d2_willys
    d2_willys
    from Kansas
    Cast Iron Glides are pretty short too, as I just picked one up a couple of weeks ago. About 26" long. But the 2" adapter plate must be used, increasing total length to 28". Just a thought.
