powerglide linkage spacer?
Discussion in 'The Hokey Ass Message Board' started by Smythe, Sep 15, 2009.
  1. Smythe
    Smythe
    my wife and i just put a aluminum powerglide in her 60 belair in place of the old cast one, every thing is fine but N,D,& L are so close together it jumps from R to L and you have to go back up to find D. this all takes place behind the N indicator on the column, they are that close. is there a spacer to go off the side of the tranz? thers not enough adjustment at the top for that pinch clamp, and that wont change my throw. does any one have a solution for me!? thanks for your time.
  2. xrise360
    xrise360
    Move the letters closer together.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Compare the trans shift arms,I'm betting the iron PG is longer C-C . Either lengthen the new one or move the rod hole on the column arm closer to the collum.
  4. dave lewis
    dave lewis
    from Nampa ID
    Kugel makes a shift arm kit that is adjustable for throw. I have used it several times with great sucess.
    It it not listed for glides, but you could adapt it with a little effort.
    The splined drum, and slotted arm arm the key to making it work.
    I think you could weld the splined drum to the p/g arm.....Make sure you weld it centered on the pivot point.
    Good luck
    Dave
  5. Smythe
    Smythe
    thanx ill look in to that from kugel and see what i can come up with
  6. 56sedandelivery
    56sedandelivery
    The shift patterns are completely different for cast iron vs aluminum Powerglide transmissions. Maybe if you take the "detent" off the column, under the hood, you could at least get all the gears. Does'nt Late Great Chevy or someone make a new shift indicator lense for this? Butch/56sedandelivery.
