powerglide problems
Discussion in 'The Hokey Ass Message Board' started by willie57, Jul 14, 2008.
  1. willie57
    willie57
    from wisconsin
    the powerglide in my el camino will not shift into high until the water temp. gets up to 180. does anyone have any ideas. thanks
  2. DualQuad55
    DualQuad55
    from NH
    This may be a stretch, but make sure the filter is not clogged. If so the cold ATF may be too thick to flow through easily. However, this usuall will cause a slip condition more than a no shift. You could have seals that are getting hard and need to heat to soften a little as well.
    I know these are sort of 'out there' but with out checking line pressures fluid levels etc... it is hard to make a good diagnosis.
  3. d2_willys
    d2_willys
    from Kansas
    what year El Camino, the later ones might have had a temperature vacuum switch that only opens when the engine warms up, and possibly the vacuum modulator is connected to it by mistake.
  4. Scrawny
    Scrawny
    from Wizkaahsin
    mine does the same thing, i am putting on a new vacume modulator tomorrow....
  5. willie57
    willie57
    from wisconsin
    Its in a 1965 el camino once it gets up to temp it shifts fine.
  6. d2_willys
    d2_willys
    from Kansas
    Try the VM first, and make sure the vacuum line is in good shape and hooked to a good vacuum source from manifold, not carb.
  7. sdluck
    sdluck
    Had this happen on my 1967 elcamino with a glide,Unhook the vacuum line from intake ,hook up a mitey vac to vacuum hose pump to 18 in of vacuum,see if it holds,if so vacuum line and modulator is ok and the governer is stuck.
  8. hotrodjohnny77
    hotrodjohnny77
    Modulator is most probable cause, simple fix.
