Hot Rods Powerglide shifter
Discussion in 'The Hokey Ass Message Board' started by silent rick, Mar 11, 2026 at 3:22 PM.
  1. silent rick
    silent rick
    is the shift lever on this powerglide set up for a floor mounted shifter or column mounted?
    If it is column, is it easily adapted to floor shift without pulling the trans apart?
    It faces down in park. Correction, that is neutral in top photo.
    This photo shows the shifter all the way forward in park which leads me to believe it was originally a column shift
  2. squirrel
    I looked at the 62 corvette ***embly Manual, which was the first car to use the aluminum PG, and it had a floor shifter, and the diagram shows the lever going UP from the pivot. So I think you're right, it's column shift.
    silent rick likes this.
  3. silent rick
    silent rick
    I knew you would respond to this thread, my go to all things Chevy guy
  4. squirrel
    thanks
    Are there aftermarket levers for aftermarket cable type shifters? Might be for that, also?
  5. silent rick
    silent rick
    Trans came with a fancy aftermarket pan with a drain plug, I'll ask my cousin (my trans guy) if I can get to it by pulling the pan and valve body and if i can turn it 180 degrees or if i need to use a totally different shift lever.
    I might have another plan, I'll let you know if it works
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...but did the Corvettes with aluminum Power glides have a backwards shift pattern? I believe that the earier ones with cast iron 'glides did.
