Hot Rods Powermaster alternator
Discussion in 'The Hokey Ass Message Board' started by scoop, Mar 17, 2025.
  1. scoop
    scoop
    Can gm powermaster alternators be clocked? I need the plug to be at 9 oclock. The ones I have seen are at 3 oclock.
  2. squirrel
    If it's a 10-SI or 12-SI alternator design, then you should be able to clock it. Just be careful with the brushes, look for tips on how to keep them in place.
    Tow Truck Tom and mad mikey like this.
  3. 325w
    325w
    What he said.
  4. scoop
    scoop
    I looked at one at a swap meet, I didn't see any holes in the back to lock the brushes from coming out.
  5. 325w
    325w
    It would be very small like just bigger than a paper clip
  6. squirrel
    Since the alternator was ***embled, it must have a way to keep the brushes in place while ***embling it.
    2OLD2FAST likes this.
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    >>just be careful with the brushes>>
    Yes, if you're careful slowly prying the 2 case halves apart till they just clear one another, the brushes will stay in place on the rotor. Then turn halves to re-clock. Push/tap them back together. No need to try to lock brushes in their holder beforehand.
    squirrel likes this.
  8. Mike VV
    Mike VV
    from SoCal
    As has been said...why sure.
    BUT...see in red above...
    Mike
    Jack E/NJ likes this.
  9. squirrel
    Exactly. I did this recently, no problems.
    But if you do let a brush pop out, you have to take it apart, and then you put the brushes back in, with a piece of wire to hold them in place. The wire sticks through the hole in the case. Once it's ***embled, you remove the wire.
