Powersteering blues Help needed!
Discussion in 'The Hokey Ass Message Board' started by Essex_29, Jan 7, 2011.
  1. Essex_29
    Essex_29
    from Finland
    I'm working on a 1957 Pontiac, and read an old article about a Saginaw 605 from a late seventies GM car working good in a '55. The pitman arm dropped right in.
    I have a steering box from a 1987 Firebird which I was going to use, but the splines on this box are a bit bigger than those on the '57.
    Anybody know where to get info on these steering boxes, and what box I could find those slightly smaller output shaft splines on.
    Thanks for any help!
  2. squirrel
    is that 87 steering box the 800 series with the bolt on top cover? or is it a 605 with the round top cover held in by a snap ring?
    afaik the 605 has the same splines as most manual GM boxes, but the 800s are bigger.
    also the insides of the 605 scare me, I'd rather run the original manual steering and build up my biceps
  3. Essex_29
    Essex_29
    from Finland
    Yes, it has the bolt on cover, guess that's the problem then, if the 800 has bigger splines...
    What's so bad about the insides of a 605?
  4. squirrel
    Oh, there just isn't much there. No recirculating ball thingy....just a threaded worm and a nut.
    This is the big gearbox you have
    This is the 605
    But I guess they work, lots of chevy guys use them.
  5. I used the 605 box in my old 59 El Camino. ONly hiccup in the install was I need to use a manual drag link, and my car was an orig P/S car with the separate hydraulic ram type power assist. 605 box worked good and did not have any problems. Although I sold the car after about 1 year of driving, it went to Sweden when I sold it.
  6. Essex_29
    Essex_29
    from Finland
    Seems a 605 could solve my problem then. In which cars did they come? Could I find one in a Cutlass/Chevelle 1978 up?
    I live in Finland and it's hard to find affordable junk sometimes...
  7. indyjps
    indyjps
    Stole this from another site, Jim Campbell seems to know his stuff. Im trying to figure this out also for 1963 impala direct bolt on.
    Im not so worried about the hoses, most cars need new ones anyway. My main concern is using the Impala Pitman and faster steering ratio. Ill probably pull a late model powersteering pump to be sure I have adequate line pressure.
    GM Box Interchange - Provided by Jim 'Canuck' Campbell
    A list of direct bolt-on boxes and some that need modifications.
    (Note this list refers to Saginaw 605 Power boxes but would probably apply to manual as well.)
    Interchange #706
    Buick Special 64-70 Camaro 67-74 Chevelle 64-70
    Chevy 65-70 Firebird 67-73 Grand Prix 69-70
    Monte Carlo 70 Monza 75-79, 8cyl Monza 78-80,6cyl
    Nova 68-70 Olds 64-70 F-85 64-70
    Pontiac 64-70 Skyhawk 75-80 Starfire 75
    Starfire 76-80, 6 cyl Starfire 77-79, 8cyl Sunbird 76-80
    Tempest 64-70
    Fast Ratio Box: 20/1 # 7806396 Cast No. 5679142
    Monza/Vega Box: 16/1 # 7819935
    On some 64-70 the drag link hole on the pitman arm may need to be enlarged.
    The following boxes will fit but may need to have the pitman arm and/or the rag joint changed or and extra bolt hole boss taked off the steering box. Make sure you compare the input shaft length or the length from the bolt holes to the end of the input shaft to your power box.
    Interchange #999
    Apollo 73-75 Omega 73-79
    Chevelle 71-77 Skylark 75-79
    Monte Carlo 71 Regal 73-74
    F-85 71-72 Nova 71-79
    Lemans 72-77 Cutlass 76
    Ventura 71-77 Phoenix 77-79
    Century 73-74 Tempest 71
    GMC Sprint 71-77
    Cutlass 73
    Interchange #989
    AMC Ambassador 70-2
    AMC 77-80
    AMC Spirit 79-83
    AMC Hornet 70-77
    AMC Concord 78-83
    AMC Matador 71-76
    AMC Gremlin 70-78
    Interchange #1034
    Jeepster 72
    Jeep 73-83
    Jeep CJ & DJ 72
    Jeep CJ 84-86
    List was derived from Hollander Interchange Manual
    Fast ratio Power Steering- Saginaw 605
    Use box from 1977-81 Camaro/Firebird with disc brakes (or any 800 series box used in Novas, full size GM, etc), gives approx 3 turns lock to lock, versus original power steering 4.5 turns.
    All later model boxes require the 1964 - 72 Chevelle pitman PS arm (required change) when used on earlier Chevelles.
    Steering shaft comes in two diameters, get the appropriate flex coupling lower half in the same style as original to match the boxes shaft.
    1982 or 86 to 92 Comaro Z-28/firebird Trans-AM are 2 turns (12:1) lock to lock, Use original end cap to get the right stops on 2 turn boxes to decrease turning radius.
    Later model boxes (1980 and up) use "O" rings instead of flared input and output lines. Later model internals can be swapped into early boxes to eliminate problems with line fittings and stops or pump can be modified by changing outlet valve (this requires verification) or swapped to accept "O" ring hosed.
