Hot Rods pre oil
Discussion in 'The Hokey Ass Message Board' started by nwbhotrod, Dec 2, 2015.
  1. nwbhotrod
    nwbhotrod
    from wash state
    Iam trying to pre lube my rebuilt 327 using drive on the oil pump. got 40 pounds oil pressure lots of oil on driver side rockers p*** side dry no oil at all. do I need to have the dist. in the block to get oil to the p*** side lifters
  2. squirrel
    yeah....I think so. The housing seals an oil p***age.
  3. nwbhotrod
    nwbhotrod
    from wash state
    thanks Jim I am going to take a old dist and try it
  4. DDDenny
    Don't put excessive downward pressure, especially if using a 1/2 in drill motor as the oil pump cover can get scored, leading to pump familiar.
  5. A proper pre oiler is built just like the distributer shaft housing.
    You don't just pump it you also rotate the motor ( by hand) while you are oiling it.
  6. squirrel
    My pre oiler is built from an old distributor.
  7. Mine too. I got a GM, an FE Ford, Chrysler. Every time I get a throw away distributer from someone's build or in a box if junk I make another.
  8. saltflats
    saltflats
    from Missouri
  9. 49ratfink
    49ratfink
    yeah, what those guys said.
    Donald A. Smith likes this.
  10. nwbhotrod
    nwbhotrod
    from wash state
    That did it I got oil to the p***s. side now
    squirrel likes this.
  11. ROADSTER1927
    ROADSTER1927
    You need to turn over the crankshaft while oiling to get all the places oiled. Gary
