Precise Alignment with a Digital Level
Discussion in 'The Hokey Ass Message Board' started by scottybaccus, Nov 1, 2009.
  1. chalkboard
    chalkboard
    I want to Thank Scotty for reposting the photos on this thread when they disappeared. This is one of the most helpful threads I have seen on the HAMB and we can all probably use the info here sooner or later.
  2. Kyron
    Kyron
    from Peoria Az
    Wish I would have seen this post 2weeks ago.......
    I would have bought some new tools ;)
  3. Thommyknocker
    Thommyknocker
    from Colorado
    Just another success story using this method :D
    I helped my neighbor rebuild the front end of his 2005 suburban.
    He came back from the alignment shop with the report, and here is how far we were "out" using string
    Caster right on, they added a bit more on the p*** side
    Camber +1/2 deg to much on the p*** side
    Total toe 0.6 deg to much toe, the specs are almost dead straight on this one.
  4. k32t
    k32t
    from Hog town
    thanks for the time and sharing a line
  5. Thommyknocker
    Thommyknocker
    from Colorado
    I just finished rebuilding the front end on my 50
    Its a mid 70s f body subframe
    +0.5 deg camber
    +3.75 deg caster both sides
    1/8" total toe
    Its got a bit of a pull to the right.
    So more caster on the right helps drive it to the left?
    Thanks
    Edit
    Found what I was looking for, sounds good to me I'll try it out
    STEADY PULL
    This is a condition where the vehicle continually pulls or drifts to one side while traveling straight. The driver typically has to maintain steady pressure on the steering wheel to keep the vehicle on the road. Possible causes include:
    • Uneven camber side-to-side. Too much cross-camber can make a vehicle pull or lead towards the side that has the most (positive) camber or away from the side that has the least (negative) camber. "
    http://www.aa1car.com/library/steerpul.htm
  6. scottybaccus
    scottybaccus
    Wow! Kick *** that y'all still use this thread!
  7. stimpy
    stimpy
    got my O/t exploder to the alignment shop 20 miles away , and was barely off the tech said . and I used a old style inclinometer with a magnetic base to set it up . the old eyes trying to read the dial were the problem .
    wish I had this info years ago instead of spending the dough .
  8. racer_dave
    racer_dave
    Great thread. On the circle track cars we find the C/L of the ch***is, square the rear. String the car off the rear end and then set the front. Order I've used is toe, caster, camber, repeat.
    The circle track supply houses all carry a caster/camber gauge that has a magnetic base to fit the wheel hub. It makes this a lot easier.
    Didn't see bump steer mentioned. A lot of times a bad alignment is actually bump steer. Adjusting that is a complete thread on its own.
  9. gmc1941
    gmc1941
    This thread is a cl***ic example of true hod rodding and can't be replaced. Thanks Scotty
  10. Luis A.
    Luis A.
    This thread looks like an 'oldie but goodie' too bad the pictures disappeared; or is it just my computer...?
  11. Dangerous Dan
    Dangerous Dan
    They are gone, darn it all to hell.
  12. scottybaccus
    scottybaccus
    Pics are back up!
    David Gersic likes this.
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    This article is from 2009.
  14. jetnow1
    jetnow1
    from CT
    and still one of the best tech articles on here.
    Truck64 likes this.
  15. Kan Kustom
    Kan Kustom
    X 2 ^^^^^^
  16. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks Scotty!
    This one is my go to when I do front end work. I've stopped going to the alignment shop now
  17. pprather
    pprather
    Great tech.
    I have a buggy sprung, solid axle rod.
    Is there a consensus on alignment specs?
    Thanks.
    Sent from my Nexus 7 using The H.A.M.B. mobile app
  18. pprather
    pprather
  19. gatz
    gatz
    thanks Scotty for showing how this "magic" is done. I've saved this to a file.
    Years ago, when working for an independent shop, we used somewhat the same procedure with a car raised up on stands and some funky-looking (commercial) swivel pads under each tire that allowed the angular movements.
    The camber was checked/adjusted with a 90deg gadget that magnetically attached to the hub face.
    IIRC, it was something like this....
    (This req'd removing the dust cap, but no big deal)
    We got good results and satisfied customers.
    Never understood exactly what was going on, but this article shed light on it.
    Thanks again,
    gatz
  20. Flathead Dave
    Flathead Dave
    from So. Cal.
    Yes it is. That's why I said it was from 2009. I like good posts that hang around.
