Hot Rods Predicament: move the crossmember, or shorten the hangers?
Discussion in 'The Hokey Ass Message Board' started by steve hackel, Mar 9, 2024.
  1. steve hackel
    steve hackel
    I am working on a 33 pick up with a stock drive line & suspension - initially my plans were
    to just add hydraulics and enjoy the 4 banger, as is ..... :rolleyes: I'm seriously considering a
    T-5 upgrade, but that means an open drive line for the conversion. There are open drive
    rear end conversions for the 33, but currently everyone is out of stock. I have a rebuilt 46 pick up truck open drive rear end that seems like the next step to take, but here lies the
    problem I see. The center line measurements of the 33 rear ends spring hangars to the
    center of the axle bell is 4-3/4" , and the center line measurements of the 46 rear ends spring hangars to the center of the axle bell is 7-1/4" - or - a 2-1/2" difference :eek:
    Mounting the stock 33 spring onto the 46 rear end moves the axle assembly 2-1/2" farther
    forward than the stock 33 axles position. At present this leaves me with 2 options
    #1, shorten the rear spring hangars by the 2-1/2" difference, or #2, relocate the cross member to the rear of its original position by 2-1/2" At this point, Is there another option that I have over looked ? What is the easiest, what is the safest, what problems
    do you see in this situation - I am open to any and all suggestions. Thanks, Steve ;)
  2. NoRust
    NoRust
    Keep the '33 traditional. Own 2 Hot Rods. Buy a newer hot rod to go faster and to be more reliable. But do not post it here. Have fun!
  3. steve hackel
    steve hackel
    I already have 2 ! My 34 - 5 window is just that, but it doesn't answer my questions.....:confused:
  4. rustythumb32
    rustythumb32
    can you replace spring with a '35-'40 spring?
  5. redo32
    redo32
  6. alchemy
    alchemy
    The spring problem is commonly cured by using the late spring, and grinding the side of the leaves so it will slide up into the curved crossmember. I’ve never done it, but many others have and said it works just fine.
    31Apickup likes this.
