preparing a frame for paint?
Discussion in 'The Hokey Ass Message Board' started by Dragrace66, Dec 27, 2003.
  1. Dragrace66
    Dragrace66
    My model A frame has some dents after sandblasting and cleaning. I want a good looking clean frame so how can I fill the dents, is lead a good idea? Is there a special kind of paint or can I use the same paint as the body? I know trucks has a special chassis paint.
  2. Harrison
    Harrison
    I'd shoot it with an epoxy sealer (DP) and then use a high-quality body filler on the dents (Rage Gold). Then shoot it with some high build primer and paint over that.
    That should net some pretty slick results.
    JH
  3. Machinos
    Machinos
    Is Rage Gold more flexible than, say, Bondo?
  4. Harrison
    Harrison
    More flexible? Not that I'm aware of but it is a much better filler. It won't stain whatever is sprayed over it and sands like 80 grit through drywall spackling (compared to Bondo which sands like 400 grit through concrete).
    When I worked for BC we did every chassis this way. None ever cracked, peeled, flaked, or gave any other problems.
    JH
  5. andysdeuce
    andysdeuce
    If'n you want a slick frame do like Harrison just told 'ya. The epoxy sealer will seal the frame and the high build primer will take care of any small imperfections you happen to miss. Never used the Rage Gold filler before but it sounds like a good product....I'll try it next time. Good luck.
