preparing for my first engine build
Discussion in 'The Hokey Ass Message Board' started by theMule, May 6, 2007.
  1. theMule
    theMule
    i have a '51 chrysler 331 hemi that i have just started to tear down. this will be my frist complete engine build. i have ordered tex smith's complete chrysler hemi engine manual, as i have been told its a must for anyone building an early hemi. i was wondering if there was any other books or maybe online source that would help me out as i don't know 100% of what i am doing.
  2. George
    George
    The hemi tech index link is at the bottom of Scooter McRad's posts if seach doesn't get you there. Look at Doc Fromader's 331 partial build & Dodge Hemi build on Webrodder, www.hothemiheads.com has parts, a cl***ified section & a newly reactivated tech forum, also www.thehemi.com
  3. Dreddybear
    Dreddybear
  4. theMule
    theMule
    thanks very much guys. i've been on hothemiheads.com quite a bit, i just had to order an engine cradle from them today cause the 750lb rated engine stand i have can't quite handle the 331 bolted on it.
    as far as the actual build goes, i am sending it out to be bored, zero-decked, perhaps minor machine work to the heads, but other than that i am planning on tackling eveything else myself. if there anything anyone would suggest a first time engine builder not to attempt?
  5. I would stay away from thermal cleaning most engine rebuilders have been forced to switch to - the baking process will remove the heat treatment of any hardened parts (i.e. crankshaft, valve seats, etc...) and require otherwise unnecessary machining to restore the surface finish.
  6. swimeasy
    swimeasy
    Just beware of most local "pros" because there is a lot of bad advice out there. The HAMB will serve you well cause all the best in the world hang around on this board.
