Prepping an alum rad for paint qun....
Discussion in 'The Hokey Ass Message Board' started by rat bastad, May 26, 2011.
  1. Hey guys,
    I want to paint the tanks/frame flat black and the core will get a super lite dust coat of flat black as well.
    What do you guys use to prep aluminium/rad for paint?
    Rat
  2. damnfingers
    damnfingers
    Metal etch primer and POR-15.
  3. blt2go
    blt2go
    i use an etching primer. clean with prep solv or somethng like it then shoot some etching primer then shoot your paint. you can get the etching primer in a spray bomb from martin senour and i'm sure others. good luck.
  4. 58 wagon
    58 wagon
    from tucson,az
    a few coats of green etch primer and at least 150 grit paper to start with on the alum it tends to peel with finer grit over time
  5. Thanx for the heads up fellas....
    Rat
  6. langy
    langy
    Degrease and 1 thin coat of epoxy primer, then your choice of top colour, Done all mine that way and it lasts.
  7. Koz
    Koz
    Not to hijack but will painting an alminum radiator affect it's cooling ability?
  8. yes, talk to any radiator shop...they use a special thin paint....
  9. Not if its a light coat...
    I use alumaprep and semiflat black krylon. Last one I painted is still going strong 8 years later.
  10. langy
    langy
    Not noticed any difference but keep the coats thin and light obviously.
    Sent from my iPhone using TJJ
