Technical Primer for Aluminum
Discussion in 'The Hokey Ass Message Board' started by 4-banger, May 15, 2022.
  1. 4-banger
    4-banger
    from Tucson
    What is a good primer for use on machined aluminum (scuffed up with some 220 grit)? I'd like to infill some machined pockets with 1 shot lettering enamel or something similar that is high gloss black and can withstand the elements.
  2. oldiron 440
    oldiron 440
    I use PPG epoxy primer for aluminum but there’s a prep coating that goes down first.
  3. chopolds
    chopolds
    from howell, nj
    In the good old daze, there was a 2 step process to treat the aluminum before painting, then the recommended primer was Corlar. Nowadays, a good sanding and epoxy is probably the best bet.
  4. Isn’t there an etch primer used for aluminium?
  5. White vinegar can be used as the cleaner and for the etching, lots of folks are painting aluminum heads with just engine paint and no primer with success. Or additionally you can get a can of etching primer....
  6. 1952henry
    1952henry
    Alodine was used for a time, iirc.
  7. chevyfordman
    chevyfordman
    Airplanes have all their bare aluminum sprayed with Zinc Chromate
    anothercarguy and jaracer like this.
  8. 1934coupe
    1934coupe
    chevyfordman beat me to it, Zinc Chromate primer for aluminum was used in the good old days.
    Pat
