Technical Primers?
Discussion in 'Traditional Customs' started by Nikki Mora, Mar 24, 2018.
  1. Nikki Mora
    Nikki Mora
    So we have decided to take a break on our Buick for the next 19 days to help my dad get his 54 f100 ready for NSRA southwest Nats in OKC. So here is my question: painting this truck in 19 days is not an option what primers are out there now that we can shoot the truck in and be able to drive it like that for a little while and be able to do body work over the top of later? He prefers a flat black primer but not sure if there is anything like that..
    Any suggestions
    Thanks
  2. john worden
    john worden
    from iowa
    Black epoxy primer like PPG DP90LF would work.
    tb33anda3rd likes this.
  3. Used Up Junk
    Used Up Junk
    from Merced, CA
    DP90 would be ok as long as it’s kept out of the elements. It seems to get “ashy” quickly in the sun and I’m not sure but I don’t think it’s a sealer so it tends to absorb moisture and other contaminants that could make it hard to work with down the road. I’m not a pro body guy that’s just been my experience with it. We’re doing the custom work and body work on the truck in my avatar right now and a couple of the body guys in our club have told me to make sure I get a true sealer if I’m not going to topcoat the finish for a while.
  4. DRD57
    DRD57
    Southern Polyurethane's black epoxy primer is excellent. It has UV inhibitors so it doesn't chalk up like DP90. It's a bunch cheaper too.
    DeLuxe 32, da34guy, mikhett and 3 others like this.
  5. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    S.P.I. Epoxy on Black.
    VR&C.
    DeLuxe 32 and da34guy like this.
  6. john worden
    john worden
    from iowa
    According to the PPG DPLF epoxy primer product information sheet it can be converted to a sealer by adding the recommended amount and type of reducer.
    I've used much of it both ways.
    For use on the street, sealers used according to directions and without a top coat, won't offer much protection.
    DeLuxe 32 likes this.
  7. lippy
    lippy
    from Ks
    I have never used DP90LF and let it cure and tried to sand it and continue later because it's a ***** to sand. But DP is tough as nails. Doing many corvettes I use to shoot the raw gl*** with DP, let it get tacky and Immediately put a urethane primer over it, maybe two or three good coats. Then come back and block the urethane primer as needed and seal and shoot color. But then I always did all my bodywork Before the DP. So all I had was blocking the urethane primer to do. Most people believe in doing their bodywork Over the epoxy. I ain't one of them. Your results may vary. JMO. Lippy
  8. dmdeaton
    dmdeaton
    I am in the market for almost the same. But I am going to keep mine this way. I am interested to see what you guys suggest also.
  9. PPG EPX epoxy
    908 should be the black
    its from their commercial line, has a 1:1 mix ratio
    the tech guy claims its the old DP 90
    lays down real nice and a lot cheaper to use than the newer epoxies from the automotive line
  10. Ppg CRE epoxy.
    Good stuff!
    Sand very well.
  11. mikhett
    mikhett
    from jackson nj
    SPI black epoxy.I LIKE TO USE WHITE THen GUIDE Co AT WITH RATTLE CAN BLACK LACQUER,66 YR OLD EYES!
  12. kgp50
    kgp50
    Like both PPG and So. Poly epoxies... but especially SP considering price. I've routinely sprayed cleaned, bare metal with epoxy, stored the part and pick it up again months later for finishing. Always sand before proceeding. Have had equally good results with sanding then filler work or with sanding, re-apply epoxy, then filler work. Probably feel most comfortable with re-applying epoxy first and getting filler down while epoxy coat is still open. So. Polyurethane specifies 7 days max for filler over epoxy without sanding first.
  13. crminal
    crminal
    SPI epoxy primer. Spray it, use it and it will look the same next year. The black has a satin sheen to it.
    Paint it and do bodywork over it.
    Great customer service and prices
  14. Cirilian
    Cirilian
  15. boring-hop-yard
    boring-hop-yard
    I use SPI epoxy black, it is the good stuff and well worth it.
  16. da34guy
    da34guy
    Anutter vote for SPI
  17. Nikki Mora
    Nikki Mora
    Thanks everyone for the feedback!
  18. Hud I
    Hud I
    from Tennessee
    Getting ready to use some SSL black epoxy primer. Has anyone used any of it before?
  19. mcmopar
    mcmopar
    from Strum, wi
    Maybe I missed it, but do any of these primers, protect the work from the elements, without top coating? As far as I know primers will soak up water, and wreck any work you have already done. Please correct me if I'm wrong.
    Tony
  20. john worden
    john worden
    from iowa
    2 part primers most likely protect better than 1 part primers but in general primers are not designed to protect from elements w/o top coating.
    "Use at your own risk" applies here.
  21. crminal
    crminal
    Epoxy primers will not soak up water. They are 2 part catalyzed and become a solid foundation between properly prepared metal and paint finishing.
    SPI has UV inhibitors and will keep its satin sheen for quite some time.
    Nikki Mora and lothiandon1940 like this.
