Problem, engine RPM "hops"
Discussion in 'The Hokey Ass Message Board' started by ItalianStallion, Jul 22, 2007.
  1. ItalianStallion
    ItalianStallion
    from Jersey
    This just started happening today. I first thought that it was a problem with the transmission slipping, because it felt like it would slip then regain and keep doing that. But then I put the car in neutral and kept the engine at about 2500 RPM. Sure enough, after a few seconds it would hop between 2000 to 3000 RPM for about 3 - 5 seconds and then keep the desired 2500 RPM again. This happens when driving, but it doesn't seem like there is a certain pattern to it. Just happens every once in a while. Also, the "check engine" light turns on when it happens every once in a while, but then after the 3 - 5 seconds of engine RPM hopping, the "check engine" light turns off.
    What do you think this is? It's so inconsistent, doesn't always happen under certain driving conditions.
  2. elwood blues
    elwood blues
    I assume its a late modle car with fule injection? If so you might want to replace your O2 sensor do a good tune up check your mass airflow sensor and your throttle position sensor. A vacume leak could also couse this. I hate chaseing down efi problems myself if this was carbed it would be ether a vac leak or maybe and ignition problem much easyer. IMO
  3. axeman39
    axeman39
    from Saco Maine
    If its a top fuel Hemi , Its normal;)
